1997 Civic CX alignment issue
Symptoms
The ride height is off on one wheel or the fender is drooping. The steering wheel favors left when driving straight.
Here is the before and after alignment specifications. I would like to install coil overs but I want to fix my current right front camber issue and steering wheel being off.
Before Measurements
Left front 0.0° Camber
Left front 1.1° Caster
Left front Toe -0.05° (Out of specification)
Left rear -1.1° Camber
Left rear 0.22° Toe (Out of specification)
Right front -1.5° Camber (Out of specification)
Right front 1.2° Caster
Right front 0.40° Toe (Out of specification)
Right rear -1.9° Camber
Right rear toe 0.05° Toe
Total Toe front 0.35° (Out of specification)
Front steer ahead -0.23° (Out of specification)
Right rear 0.05° Toe
Rear total toe 0.27°
Thrust angle 0.09°
Current Measurements
Left front -0.1° Camber
Left front Toe -0.02°
Left rear -1.3° Camber
Left rear 0.06° Toe
Right front -1.3° Camber (Out of specification)
Right front -0.02° Toe
Total Toe front-0.04 °
Front steer ahead 0.00°
Right rear -1.8° Camber
Right rear toe 0.10° Toe
Rear total toe 0.16°
Thrust angle -0.02°
Before Measurements
Thrust angle 0.09°
Left rear 0.06° Toe
Thrust angle -0.02°
Cool Cool Island Breezes. BOY-EE
Maybe one of your angles slipped or didn't hold because of a bad bushing or ball joint or tie rod.
Or maybe one of your tires has some issue. Try swapping front tires side to side. Then rear tires side to side.
My buddy just installed trailing arm bushings for me. This seemed to help the steering wheel being off. Could the trailing arm bushings effect the front camber being off on one wheel too or do you think I still need front adjustable camber kit?
Did he install them before or after the alignment?
The amount of camber difference between the fronts (~1°) is slightly abnormal....but not really. The engine is on the RF corner. So that is going to be a bit heavier. With you in the LF seat (assuming LHD), the angles will look more similar. This looks like a stock height car. Has it ever been in an accident? Are any front bushings worn?
I wouldn't get a camber kit. You might introduce new issues....and the angles you have don't warrant any alarm or additional camber adjustment. Leave it alone unless one of the parts is worn or busted.
AzntaggeR
18
May 1, 2004 03:21 AM
