Car quits running while driving read list of what has been done
Old Mar 6, 2014 | 04:28 PM
Cmatrooper's Avatar
Default Car quits running while driving read list of what has been done
I have a 90 dx hatch. I got into a small accident in December and have replaced numerous things since. My car can be driving 15-80mph and just randomly lose acceleration and rpms go up but car slows down then shuts off when it gets to a stop. Here's a list of what I've done to it all parts are brand new not reman parts. No codes on ecu either and it's a dpfi
Fuel pump and strainer, fuel filter, alternator, pcv valve, egr valve, distributor, icm, coil, plugs, wires, cap, rotor, fuel lines, engine temp sensor, oxygen sensor, catalytic converter, air intake temp sensor, main relay, new battery can someone please help I need to fix this before I go to drill on base 277 miles from my house
Old Mar 6, 2014 | 04:40 PM
ownedevo10's Avatar
Default Re: Car quits running while driving read list of what has been done
First give some more info on the accident. Was its front collision or rear? Could help to figure out problem. Also all the parts you replaced was that because you are chasing the problem or did you do that for maintenance?
Old Mar 6, 2014 | 05:34 PM
Cmatrooper's Avatar
It was a front end collision and chasing the problem
Old Mar 6, 2014 | 06:32 PM
bgdriver's Avatar
hook up a fuel pressure tester and run it out the window taped to the windshield or something ghetto and do the same with a volt meter hooked up to coil power and thermostat ground. Drive around and see what happens when it dies then chase down problems in that system rather than running around in circles throw parts at it all haphazard like. New parts can be faulty too.
Old Mar 7, 2014 | 03:55 AM
Cmatrooper's Avatar
Thanx I'll try that today
Old Mar 7, 2014 | 08:09 AM
Cmatrooper's Avatar
Everything is at it's normal operating ranges i think it may be the injectors or a fuel pressure regulator
Old Mar 7, 2014 | 08:12 AM
Freemananana's Avatar
Drill on base? 277 miles from home? That just sucks.
Anyways. On topic. Is it automatic? Couldn't it be that pressure plate thing they have going bad or something?
Old Mar 7, 2014 | 11:45 AM
Cmatrooper's Avatar
Well I have all the stuff for a manual swap on the way and I have a friend that does a amazing Job doing a dpfi to mpfi and obd0 to obd1 gonna try those and if it's still there then I have no clue and yes going that far for drill really does suck I pass 4-6 bases on my way there I'm just glad I had the problem around home and not on my way there
Old Mar 7, 2014 | 11:48 AM
Cmatrooper's Avatar
Btw explain how the automatic trans can cause that problem this is my first auto so not really tech savy on autos only manuals and they were easy to work with when something went wrong
1SlowSiHB
Dec 21, 2009 04:47 AM
ScandalousCivic
May 10, 2005 06:20 PM
therealciviczc
Sep 4, 2004 03:41 PM
ricky_gunns
Apr 15, 2003 11:19 PM
