replaced coolant temp sensor, problem still exists!
Old Apr 15, 2003 | 10:00 PM
ricky_gunns's Avatar
Default replaced coolant temp sensor, problem still exists!
can anyone help me out of this jam that's been haunting me for the past couple weeks already. problem is hot re-start. i found out that my 90 acura integra does not supply any fuel after the car is warmed up while trying to re-start. already replaced fuel pump, cts, distributor, main relay. now im thinking pcm? can anyone help me out with this problem? much appreciated!!
Old Apr 15, 2003 | 11:19 PM
hatchy's Avatar
Default Re: replaced coolant temp sensor, problem still exists! (ricky_gunns)
wow, sounds like you've replaced almost everything. Have you checked your injectors, are you sure they are okay? Clogged fuel filter or return line? Maybe a broken FPR?
I had the same problem, and it turned out to be a bad fuel pump.
Toadfart
Oct 11, 2009 05:54 PM
ErMaK
Oct 13, 2004 11:54 AM
Magick211
10
May 1, 2004 09:44 PM
CrazyCorey
Jul 26, 2003 09:52 AM
