question on radiator switch B (h22)
Old Mar 6, 2014 | 03:50 PM
prelude2.2vtec's Avatar
Default question on radiator switch B (h22)
I have found today that the connector to this rad fan switch, the b one, (the one located in front of the block not in the thermostat has sheared off) I have a new connector and just need to know where the wires go. Theres two one black cable and a yellow/white cable. Would anyone be able to unplug this connector and just give me the color order top to bottom?Thanks in advance.
Old Mar 6, 2014 | 10:46 PM
holmesnmanny's Avatar
Default Re: question on radiator switch B (h22)
It's not going to matter which way you put them. All that happens is the switch closes and there is continuity through the switch.
Old Mar 7, 2014 | 07:15 AM
snobordboy's Avatar
Moderator
Yup, just wire them up, either way will work.
That switch just activates the fans when the car is turned off btw.
tollickj
Jul 1, 2014 04:25 PM
pab59y
Aug 2, 2011 01:35 PM
jaje
Sep 22, 2006 07:14 PM
oMek
Oct 28, 2003 05:41 AM
ImportechPerformance
Mar 5, 2002 02:05 PM
