Suspension & Brakes Theory, alignment, spring rates....
cant get my accords alignment straight
Old Mar 5, 2014 | 03:39 PM
410ruga's Avatar
Default cant get my accords alignment straight
I cant get my Honda accords alignment straight when I first got the car when the wheels were straight the steering wheel was straight I know that doesn't mean its aligned,but soon after I got the car my ball joint was squeaky so I had that replaced as well as tie rod rack a pinion boot done after that is when my steering wheel became crocked I went to have it realigned and the could not figure out what the issue was they said the frame looked to be fine where do I go from here
Old Mar 5, 2014 | 08:46 PM
viper_boy403's Avatar
Default Re: cant get my accords alignment straight
Do you have a spec sheet that they gave you? It would really help if you could show us that
Old Mar 10, 2014 | 09:18 AM
410ruga's Avatar
I don't have the spec sheet,I had all that work done in Maryland and im now in Washington I would have to go get another alignment to get the specs again,i wanted to figure out that alignment issue before I do a swap on this car but I can say it wasn't off by to much my tread doesn't wear unevenly I drove it 3000 miles across the country
Old Mar 10, 2014 | 03:50 PM
Tyson's Avatar
so what exactly did you want us to tell you?
align your toe and check your cross camber to make sure nothing else is bent.
come back with specs.
Old Mar 12, 2014 | 12:16 AM
slowcivic2k's Avatar
All I can tell you is what any compentent tech would look for:
1: Check ride height.
2: Check tire wear/pressure, replace as required, note wear/damage.
3: Check vehicle load F/R L/R.
4: Inspect suspension and steering parts,. replace as required.
5: Re-align vehicle to spec, (usually done wrong or lazily).
6: If specification cannot be attained, give reason, IE bent knuckle (common).
Cheaping out on one of these parts can yield a poor alignment. If a tie rod was seized it should be replaced, probably why you steering isn't straight.
raidacaipo
20
Feb 27, 2010 03:05 PM
EG6R
Aug 13, 2007 06:09 AM
vinuneuro
Mar 1, 2006 05:03 PM
WangChung
36
Dec 10, 2003 07:34 AM
ultimatehonda
Jul 8, 2003 03:28 AM
