What happened????!!!!!
Old Mar 5, 2014 | 01:35 PM
Gofast94's Avatar
Default What happened????!!!!!
Ok so I have a 94 civic hatch with a b18b1 I've been having issues with it running so I went to try and pull some codes but the connector sparked and now the car won't start I did try and replace the ecu but nothing and the ecu fuse is fine and all the fuses under the dash are fine please help !!
Old Mar 6, 2014 | 09:08 AM
Miguel613ekb18c's Avatar
Default Re: What happened????!!!!!
Does the ecu power up, can be checked by checking 5v reference on tps or map sensor when key. (II) on
Old Mar 6, 2014 | 01:01 PM
Gofast94's Avatar
I am getting voltage to the tps sensor but on the three pins I'm getting between 9 and 10 volts but im getting nothing on the map sensor. Also if it helps I tested the fuses 31 under the hood and I'm not getting power to it, but I am getting power to fuse 24 under the dash and I did replace the main relay but that didn't fix anything and I'm not getting spark and the fuel pump is not kicking on to prime.
Old Mar 13, 2014 | 04:43 PM
A spark usually means blown fuse
Old Mar 14, 2014 | 06:32 PM
Gofast94's Avatar
No blown fuses
Old Mar 14, 2014 | 06:51 PM
civic-steve-94's Avatar
Bust out the ecu pin out and back prob your powers and grounds. And what did you put in the connector to get sparks?
Old Mar 16, 2014 | 04:02 PM
VegasInvasion's Avatar
I'm Huge In Japan
yeah the service connector can't spark, you jumped something else. if there really are no blown fuses (which i doubt) then you may have damaged the main relay. otherwise try another ecu.
Old Mar 16, 2014 | 06:41 PM
Gofast94's Avatar
I jumped the data link it's the 3 prong and I used a wire I replaced main relay and the ecu I also replaced the fuse panel under the hood
Old Mar 17, 2014 | 06:55 AM
the DLC is two pins brown and black wires...... same area as a three pin connector though. just check all the fuses under the dash also just to be sure. find a wiring diagram and find what you did bridge.
jdmgsr420
Honda CR-V & Element
35
Mar 4, 2012 06:10 AM
b18c4dr
Apr 19, 2009 01:39 PM
rousseau8
Feb 20, 2008 11:45 AM
Xenobi
Jun 12, 2006 07:39 AM
SiHatchTurbo
Sep 6, 2005 12:48 AM
