engine dies after 2000rpm
Old Mar 4, 2014 | 07:33 AM
VTiSpec's Avatar
Default engine dies after 2000rpm
I was tunning a B16A with Brain Crower, CPR pistons, stock injectors, everything was fine but after awhile engine won't go past 2k rpm. I change ECU with stock one and keep doing it.
I will appreciate any help.
thanks
Old Mar 4, 2014 | 08:42 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: engine dies after 2000rpm
Check engine light on?
Old Mar 4, 2014 | 03:23 PM
VTiSpec's Avatar
I was using hondata S300, an IAC error code came out. it was intermittent.
Old Mar 5, 2014 | 05:17 AM
holmesnmanny's Avatar
On a stock car an iacv code will throw the car into limp mode = no 3000+ rpms
Old Mar 6, 2014 | 12:14 PM
VTiSpec's Avatar
yes, engine light came on.
Old Mar 6, 2014 | 12:15 PM
VTiSpec's Avatar
thanks, saturday I will remove IAC and replace it. I also read by cleaning it will help.
let you know how it went
Old Mar 8, 2014 | 03:39 PM
VTiSpec's Avatar
today I worked on the car and look into the IAC and found TPS Sensor unplug.
thanks for your inputs.
Old Mar 9, 2014 | 12:33 AM
sounds good...it's weird that the iacv code came up ... however on some cars you can accidentally swap the iacv and tps sensor connectors...hoping that didn't happen to you.
cprlover
Dec 7, 2010 04:35 PM
oilspot
Feb 24, 2009 10:16 AM
jdmazm
Apr 21, 2005 07:58 PM
TURBO4drTypeR
Jul 8, 2004 09:02 PM
rca90gsx
Apr 10, 2002 10:53 PM
