just barely got a 88 crx has a d16a6 needing opinions
Old Mar 3, 2014 | 08:58 PM
RustBucket88's Avatar
Default just barely got a 88 crx has a d16a6 needing opinions
I just barely got my crc was wandoering if any ome has any opinions or experince on building an a6 I was wanting some help on the build.
Old Mar 4, 2014 | 04:13 AM
Freemananana's Avatar
Default Re: just barely got a 88 crx has a d16a6 needing opinions
It's a great motor. Clean it up, replace anything that is wrong. Do a basic tune up; cap, rotor, plugs, wires, oil, coolant, ect. Get a decent 4-2-1 or 4-1 header and possibly a 2" catback exhaust. The factory air box works fine, but smooth tubing should help flow a little bit and a lot of people just like the sound of cone style filters.
I would just opt for basic bolt ons and possibly tuning if you can afford it. I'm not sure what cams are available for the D16A6. But with bolt ons and a tune I've seen them put down 116 HP and 116 FT-LBs. Which, in my opinion, is amazing for a SOHC I4. It is a great motor.
Old Mar 4, 2014 | 08:58 AM
tonekids's Avatar
Originally Posted by Freemananana
It's a great motor. Clean it up, replace anything that is wrong. Do a basic tune up; cap, rotor, plugs, wires, oil, coolant, ect...with bolt ons and a tune I've seen them put down 116 HP and 116 FT-LBs. Which, in my opinion, is amazing for a SOHC I4. It is a great motor.
Glad to hear it. The one in the car I bought had grenaded, so I found another one in Indiana.
It has been sitting on a pallet for a few years, just waiting for me to get around to refreshing it with new seals and the other assorted items.
I even sourced the OEM front pipe for it, with the stock exhaust manifold.
Old Mar 4, 2014 | 09:06 AM
4drEF's Avatar
Keyboard Humorist
If you are going with OEM exhaust manifolds, try to get one from a D16Y8. It will bolt right up and has a much improved design.
Old Mar 4, 2014 | 10:11 AM
I'll agree since 4drEF is usually right. I know the A6 exhaust manifold was less than performance oriented.
Old Mar 10, 2014 | 10:34 PM
I was thinking of just keeping the car as is and swap it out with a gsr or b16b if possible can't decide between the two options of swap
Old Mar 11, 2014 | 02:40 AM
GSR>B16B by far. The B16B is too expensive for what it is. It's been called a 'fanboy' motor for a long time.
kseries04
Nov 18, 2009 06:11 PM
M@
Nov 8, 2005 03:09 PM
Vinhtran17
Jun 12, 2005 03:37 PM
magic hat #9
Apr 24, 2004 07:49 PM
85crx
Sep 22, 2002 06:29 PM
