98 gsr intake mani/TB help
Old Mar 2, 2014 | 10:04 AM
00civicnewb's Avatar
Default 98 gsr intake mani/TB help
Hey HT
i have a 2000 civic with a 98 gsr and a Skunk2 intake manifold with a no-named 70mm throttle body. will it hurt the motor at all if i cap off the 2 pipes (one on top of TB and one on the bottom) coming off of the throttle body. and also do I cap the small pipe on the back of the skunk2 intake manifold. and also the heater bypass pipe thats under the vtec solenoid.
Scroll down to see pictures
thank you!
Old Mar 2, 2014 | 06:16 PM
Default Re: 98 gsr intake mani/TB help
Bump
Old Mar 3, 2014 | 10:22 AM
Monday Bump.
anyone able to help me out??
Old Mar 3, 2014 | 10:26 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Pics don't seem to be working
Old Mar 3, 2014 | 11:11 AM
B_Swapped93's Avatar
pic fail
Old Mar 3, 2014 | 11:17 AM
hrmm. okay give me a sec and ill see whats wrong
Old Mar 3, 2014 | 11:20 AM
Old Mar 3, 2014 | 11:23 AM
The one on top is EVAP can be capped the last pic is again evap can be capped, the coolant hoses SHOULD REALLY be hooked up that's the 2 middle pics.
Old Mar 3, 2014 | 11:29 AM
okay
so pictures 1 (top pipe),3 and 5 i can cap. then for pictures 2 and 4 i just run a hose from 2 to 4?
Old Mar 3, 2014 | 11:31 AM
yes and yes as you'll have coolant leaking if you don't connect the coolant ones.
Old Mar 3, 2014 | 11:37 AM
okay awesome. thank you a bunch for the help.
also. i capped my heater bypass pipe (front and back of motor) as you can see on picture 4. will this do any harm to the motor. i heard you can do this as long as you dont live in very cold areas. im in florida so i think im okay
Old Mar 3, 2014 | 03:44 PM
you capped them or joined them ? I'd join them to be safe, that's what I did but it's a track car so it only sees the hot summer days.
Old Mar 3, 2014 | 04:59 PM
yeah i capped them. cause its florida and we dont really see very cold days.
picture 4 is the cap. left side of the radiator hose. i used the same kind of cap for the back of the motor also
termite587
Apr 9, 2016 08:15 AM
eluminati
Jan 25, 2015 06:18 PM
00civicnewb
Aug 19, 2013 02:33 PM
Pauly_Walnutz
Jan 30, 2008 04:42 PM
dave24
Jan 5, 2006 05:13 PM
