f22b2 clutch problem
Old Mar 1, 2014 | 10:16 PM
bacarter1's Avatar
Default f22b2 clutch problem
Did a transmission swap put in new clutch, pressure plate, flywheel and afterwards the clutch just falls to the floor. At this point I replaced the slave and master, and still after a week of bleeding the clutch I can't get any pressure to my clutch. Any ideas?
Old Mar 2, 2014 | 12:04 AM
95accordian's Avatar
Default Re: f22b2 clutch problem
is it leaking do you still have fluid? did you double check every bolt and make sure of install the disc the right way?
Old Mar 2, 2014 | 11:44 PM
bacarter1's Avatar
It holds fluids, no leaking from what I can see.
Old Mar 3, 2014 | 12:43 AM
holmesnmanny's Avatar
adjust the push rod
Old Mar 3, 2014 | 07:02 AM
jollyhonda's Avatar
Did you remember the throw out bearing?
Old Mar 15, 2014 | 03:06 AM
bacarter1's Avatar
It was the clutch fork.
dragonkx
21
Mar 28, 2010 06:47 PM
blink_977
Jun 4, 2009 01:31 AM
Chiller
Nov 4, 2006 04:11 PM
InitialJRift
Sep 13, 2006 10:43 AM
o'malley_808
Nov 10, 2005 07:51 PM
