Cars For Sale: Integra TYPE-R's - Mar/Apr 2014
F/S 98 CW ITR#708
Not parting with anything, not even the ARC's sorry.
11K obo
Selling car to do fund a different project.
No trades
Shell:
98 CW JDM Front
MB motorsports 17 x 7 wheels
Wire tuck
ABS delete
Stainless steel brake lines
Pwr folding mirrors
Optional side skirts and valences
Spoon Duracon shift ****
Type r front & rear strut bars
ARC winglets
Red recaros (no rips or stains nice condition)
Personal steering wheel
NRG qr
Takata harness
usdm rear seats
Rebuilt fl title
Pioneer radio
Jl sub
Window visors
Motor:
LSV (stock bore)
9:1 cp pistons
Eagle rods
Type r crank
Moroso oil pan
MYHONDAHABIT Oil pan gasket and stud kit
Type r oil pump
ARP head studs
Avid motor mounts
Head: jdm type r
JDM type r cams
Supertech springs and retainers
Skunk2 intake manifold
Type r trottle body
Hondata 4 bar map sensor
1000 RC injectors
Transmission:
Stock ls transmission
Competition clutch stage 4
Upgraded axles
Turbo kit
Precision sc34
Tial 38mm wastegate
Tial Q bov 6 psi spring
PFAB manifold a/c comp
PWR intercooler
3" down pipe w/ race land e cut out
Devils own meth kit
Hondata s300 w/boost by gear
GM boost solenoid
AEM digital wideband
Autometer carbon fiber boost gauge
Motor made 408whp at 14lbs on a conservative tune.
Easy capable of 450+
Misc:
Buddy club short shifter
PWR half radiator
Spoon Radiator cap
Samco hoses
Complete a/c but not installed
Yokohama spec2 205 40-17 lots of life left
JDM Fender liners
PasswordJDM Cooling plate
Drilled and slotted rotors
Viper Alarm. Has other security measures i will let the new owner know
Pros:
NO leaks period.
Less than 20 miles ago the following was replaced due to car sitting
Head just got new valves and magnafluxed
New timing belt and tensioner
New headgasket
New Cam seals
New Oil pan gasket
Car was just clay blocked and detailed
Build was finished Nov 2011
Will come with new console cover
Cons:
Just had the side skirts and front bumper repaired due to damage that was done to them when car was shipped. Unfortunately the paint that was used is white and not CW white.
The mileage on the odometer reflects the engine not the chassis. Approx 100K on chassis
Car could used some better suspension. Currently sitting on no name coilovers in the rear and H&R lowering springs up front.
11K obo
No trades
Shell:
98 CW JDM Front
Wire tuck
ABS delete
Pwr folding mirrors
ARC winglets
NRG qr
Takata harness
usdm rear seats
Rebuilt fl title
Pioneer radio
Jl sub
Window visors
Motor:
LSV (stock bore)
9:1 cp pistons
Eagle rods
Type r crank
Moroso oil pan
Type r oil pump
ARP head studs
Avid motor mounts
Head: jdm type r
JDM type r cams
Type r trottle body
1000 RC injectors
Transmission:
Upgraded axles
Turbo kit
Precision sc34
Tial 38mm wastegate
PWR intercooler
Devils own meth kit
GM boost solenoid
Misc:
PWR half radiator
Spoon Radiator cap
Samco hoses
JDM Fender liners
Pros:
NO leaks period.
New headgasket
New Cam seals
New Oil pan gasket
Cons:
2001 Acura Integra Type-R PY
NONE SALVAGE TITLE but title is branded for incorrect odometer.
Authentic ITR shell and vin. Type-R rear seats. USD Type-R cluster but has a hole in it; thinking the previous owners made that hole to roll back the odometer but it shows 54k miles.
NONE TYPE-R parts.
B16A motor
LS transmission
Has front end damage. Motor was running until it sat since last summer. Never started since then.
$3700 FIRM
You need to come and tow!
Click for pictures:
https://honda-tech.com/forums/showpo...8&postcount=32
NONE TYPE-R parts.
B16A motor
LS transmission
$3700 FIRM
Click for pictures:
Did you read the entire post?
Car is damaged. Recommend it be towed. Doesn't have ITR bits.
Location is Seattle. It's shown by my username.
I can probably tow it down to socal in a few months. I'm picking up a 4th gen 4runner. You just pay for dolly and half of the gas for tow one way. I have family in LA so I can visit them and bring it down.
1998 Acura Integra Type R
140K miles
Connecticut Title ( rebuilt back in 2000 )
Asking $9,500 or best cash offer No trades of any kind.
any question text me two zero three four two four nine eight nine six.
Located In Connecticut.
I have tons of pictures of the car if you want more text me.
Engine/Transmission: Original engine and transmission matching VIN #'s with chassy.
Jackson super Charger 9 psi boost
Password JDM Intake
Hytec Header replica
Apexi N1 Exhuast
Competition Clutch,
ACT flywheel
Hard Race Motor Mounts,
RC Injectors,
Hondata Sc300,
New OEM Valve cover,
Mugen Oil cap,
Mugen socks,
Mishimoto Silicone Radiator Hose
Driveshaft Axles,
CTR pistons install with engine rebuilt
Custom spark plug wires cover
Suspension/Brakes:
EBC yellow stuff pads,
EBC rotors,
Hard Race front lower control Arm,
Buddy Club Ball Joints,
Hard Race Upper control Arm,
Form and Function 1 piece coil over,
Function7 Rear LCA with endlinks,
Hard race trail arms bushings, sway bars bushings, camber kit,
Falken Azines tires
Moog tie rod ends inner and outer
Interior:
JDM ITR recaro Seats,
JDM ITR steering wheel,
Jackson racing Boost gauge
Autometer Oil pressure gauge,
Skunk2 shift ****,
Pioneer DVD TV NAVI and rear camera
Pros: All original car with matching Vin numbers engine and chassy. Original champion ship white color Type R. All modifications where done two Years ago including engine rebuilt I have receipts for all the work the car has receive. Runs and drives. Cold A/C, all power options work. Nothing broken inside. Front and rear seats are in Mint condition. Good project to be finish !
Cons: car does have some clear coat pealing on the hood and front fenders, rock chips on the front lower spoiler, hood. very very small rust bubble on driver side rear quarter. The car does still runs and drives but due to high compression pistons and boost car would need new piston rings or valve seals replace as it burns oil and smoke only when flooring it. Also has oil leak from the corner of the head looks like the head gasket would need replacement as well. Has EBC pads and im not happy with them would suggest replacing them after couple events at the track front brakes started to vibrate when slowing down from high speed.
140K miles
Password JDM Intake
Apexi N1 Exhuast
Competition Clutch,
ACT flywheel
RC Injectors,
Hondata Sc300,
Mugen Oil cap,
Mugen socks,
Driveshaft Axles,
Suspension/Brakes:
EBC rotors,
Falken Azines tires
Interior:
Skunk2 shift ****,
98 r shell for sale in Florida. Unfortunately I was ran off the road so I'm gonna try to move the shell it was in a accident ,had the adjuster look at it and I was told it can be fixed passenger rear quarter panel and passenger fender title is clean I don't have pics on my iPad unfortunately but can text them to anyone if interested ,80k on shell,but I can say new fender is needed,passenger headlight(bracket broke) front bumper is cracked I have the 5lug and full interior as well from the car would sell it complete for 4500 i know it would be hard to determin since no pics but text or call at 8183246714 car is in Orlando fl area
IDE sell the complete car for 7k.the b18c5 runs perfect no leaks etc
http://imageshack.com/i/0yhytxj
Link to pics^^^^
Link to pics^^^^
Im in the market for a RHD real deal Type R (original not converted). I have not had any luck finding one so if anyone has any good places to buy from that are not butchered please let me know, thank you in advance!
Call me a fan boy idc, id rather just have the real deal, and not have to buy everything to make the car how i want it, the original already comes how i do want it to look and such.
Well the time has come to sell my projects cars. First off I have my '97 Integra Type-R. I purchased this chassis from a K20A forum member in 2011. Over the past two years I have worked on getting this car to it's current condition. The vehicle was a stolen recovery chassis purchased through an auction in Pennsylvania, however it now has a clear California title. The vehicle has about 36,000 miles (Original cluster is included). Here is the link to my original build thread http://https://honda-tech.com/forums....php?t=3119032
My asking price is $24,900 obo. serious buyers please feel free to call or text me directly @ (619)890-3539. If you prefer to communicate over email my email address is gilsalazar101@gmail.com
Engine: 286hp/192 TQ tuned at Church Automotive
JDM K20A stock hort block
BP Racing head studs
Mugen hi-comp head gasket
BP Racing competition head port
Supertech .05mm oversized valves, springs, and titanium retainers.
Skunk 2 stage 2 version 3 cam shafts
Skunk 2 adjustable exhaust cam gear
Circuit Hero timing chain guide
Hytech Racing baffled oilpan
BP Racing fully ported manifold. (Shaved and replumed with AN fittings)
74mm Skunk 2 throttle body with match ported Rcrew adaptor
440cc RC injectors
RCrew fuel rail
RCrew version 3 header
Asc custom 3" burns stainless exhaust with Apex WS exhaust ($1700 setup)
Hybrid racing Griffen full size radiator & hoses. Custom mounted slim push fan
Beatrush cooling plate
Custom ASC coolant tank / PCV catch can
Custom mag blue valve cover with AN fittings
Custom ASC valve cover breather tank
Full mil spec Chasebays engine wiring harness & grounding kit
Custom 3.5" ASC Cold Air intake with velocity stack & filter
Hondata Kpro w/ TracTuff ECU mounting plate
Custom braided fuel lines/FPR setup
Walbro Hi-output fuel pump
Transmission
EP3 transmission case with VIN plate
2006 Civic SI K20Z3 6-speed gear set
Chasebays clutch line
Wavetrac LSD w/new bearings
hybrid racing shifter box
Exedy chromoly fly wheel
Exedy stage 2 clutch
type s 36mm axles w/ new oem mid shaft
Exterior
Complete championship white respray ($5,100 alone)
New JDM front end purchased from ICB motorsport
3m clear bra oem bumper and lip
Walker Japan front bumper w/ custom mastercraft grill and bumper reinforcement plate by ASC
Wireworx head light wiring kit
New oem ITR decals and emblems
New oem mud guards
Authentic Ganador mirrors
Authentic Mugen Gen1 spoiler
Interior
New oem door panels
New carpet
New jdm ITR arm rest delete
Oem CF interior trim
EDM passenger airbag delete
New EDM ITR black floor mats
JDM Recaro black DC2 front and rear seats
Vision low position 1-touch sliders
Mugen DC2 cluster
Circuit Hero ****
Works bell detachable hub
Personal suede steering wheel
Suspension
Eibach Multi-Pro R2 coilovers (rear bushings upgraded to Delrin) & custom resivour brackets
New jdm 23mm rear sway bar with hardrace bushings
ASC 3-point strut bar
ASC lower tie bar
New Buddy Club roll center adjusters
New skunk 2 front & rear adjustable control arms
Arp extended wheel studs
New oem wheel bearings
Stoptech BBK with new Hawk HP pads
Brake line relocation by ASC speed metal
Mag blue 17x8+ 38 Volk CE28N
215/45-17 Federal RSR tires
440cc RC injectors
RCrew fuel rail
Transmission
Exterior
New oem mud guards
Interior
New oem door panels
New carpet
Mugen DC2 cluster
Circuit Hero ****
Suspension
ASC lower tie bar
1998 ITR #1053
Clean Title
Matching VINS
Original paint
I have owned this car since 2007. It has been extremely well taken care of and always garage kept.
The car currently has 134K on the odometer. I have had this stored for the past two years and driven less than 100 miles in that time.
The car was first purchased in Illinois. Then brought to southern California in 2000 where it has been ever since.
I have the business cards from the original purchase as well as the Acura Total Luxury Care package info that has been passed to all owners.
The interior is clean. OE floor mats will be shampooed prior to sale.
The exterior is very clean. There are a few small dings. The worst of which is on the hood, a car in front of me had a blow out and a chunk of their tire hit the hood. See photos below.
Anything not noted is original factory equipment.
Exterior
5K – HID headlights – White output
Interior
K20Mart Delrin shift ****. (Will include OEM **** if I can find it)
Engine/ Transmission
The engine is stock with VIN plates attached.
Exedy “Stage1” clutch.
ACT flywheel (OEM flywheel will be included)
Brand new battery.
Suspension
Tokico Blue Dampers
Tires
BFGoodrich G-Force sport tires
195/55/15
The bad: all of which are normal for 94-01 Integra’s.
Antenna does not retract when car is turned off.
Trunk actuator is “sticking”
Back seat tops are fading
Small chip in windshield.
VIN# will be provided to serious buyer, as well as a CARFAX print out.More photos available if needed.
13,000 - NO TRADES PLEASE-
EMAIL WORKS BEST.
JaredReyes83@gmail.com
MORE PHOTOS.
https://www.flickr.com/photos/jaredr...7641929972934/
Clean Title
Matching VINS
Original paint
Exterior
Interior
Brand new battery.
Suspension
Tokico Blue Dampers
Tires
195/55/15
EMAIL WORKS BEST.
MORE PHOTOS.
SOLD SOLD SOLD SOLD SOLD SOLD
Selling my 2000 Integra Type-R #0061
Title: Re-built
Mileage:71k
Car was rebuilt due to theft car when they stole the car they took motor tranny front end wheels front seats
car still has its original armrest with number
interior:
Recaro srds in red
Takata 4 point harness
Mugen petals
Original gauge cluster
Jdm Type-R Shift ****
Airbag Delete
Integra Type-R Checker Truck Mat
Jdm Integra Type-R Rear Seats
Skunk 2 Short throw shifter
Kenwood Double Din Tv/Nav/Dvd
Exterior:
Black Housing Non Hid Jap Front
Jdm ITR Champ white 16"
Wheels were recently powder coated
Wheels also have brand new Oem center caps
Brand new Drilled and slotted rotors
Flaken Azenis RT-615 Tires 85% tread life (215/45/R16)
Apexi Ws2 cat back
Tokico Shocks Ground Control coil over sleeves
Skunk 2 Rear Lcas (Red)
Cdm Rear Bumper Fog Light with Oem switch
All four Oem Mud Flaps
Oem Integra window visor (Drivers Side)
Motor:
2000 Jdm Integra Type-R Complete Motor Swap
Jdm Integra Type-R B18C Motor With Lsd Transmission
Motor was recently Purchased And then was installed at Braman Honda
Motor has 45,000 miles withs paper work to prove
All Honda fluids flushes have been done with Oem Honda fluids
Cold Cold A/c
Powersteering
Abs
Oem Front Strut Bar
Motor is 100% Stock
Car in located in Miami Florida Garage Kept
Asking $9,000
Contact: Eddie: (786)210-1759
Title: Re-built
Mileage:71k
interior:
Recaro srds in red
Mugen petals
Airbag Delete
Exterior:
Apexi Ws2 cat back
Motor:
Cold Cold A/c
Powersteering
Abs
Oem Front Strut Bar
Motor is 100% Stock
Asking $9,000
2000 Acura Integra Type R #1101
Nighthawk Black Pearl
Clean title, clean CARFAX
SOLD! Thanks, Honda-tech.com. He saw it here!
Want to buy a integra type r shell,would like it to be a rolling shell with 5lug could have interior but it doesn't matter,can be clean or rebuilt title, I have cash in hand and located in Orlando Florida. Would be willing to travel but a reasonable distance my number is 8183246714
Thanks
Thanks
Any trades? 98 spec usdm R
looking for a py itr or 07-08 tl type s will add cash
check out more pics on instagram @98_itr thanks.
Attachment 356634
Attachment 356634
...blocked...alright then.
Will be having a 2000 PY JRSC Type R w/ 104k miles for sale in the next week. I just have not had a change to take pictures of her yet.... just a heads up. Body is pretty flawless with an exception of a large paint chip on the front bumper do to a flying hubcap.
She was dyno'ed and pulls 232hp to the wheel.... I will list specs soon.
Not looking for any sort of trade at all. Just a straight sale.
$12,500
$12,500
$12,500
$12,500
please send pics when available
ntr1_1@hotmail.com
Cheers
Will
Up for sale is my 1998 Acura Integra Type R with 107,750 original miles. Clear title, matching VINs on all body parts. I have a printed copy of the AutoCheck report and the Carfax report, both reports were recently printed. Has the original B18C5 engine, runs like new with no issues whatsoever. The only real flaw with the car is that the previous owner changed the original Type R transmission with a transmission out of a GS-R. The transmission is out of a 2000 GS-R which had very low miles (I have the AutoCheck report and the Carfax report of the car it came out of). It's mostly stock with the exception of a few mods (mods listed below). I'm looking to purchase a NSX this year so I don't want to keep this ITR anymore. I'm asking $13,500 for it. Cash only, no trades (unless it's a NSX). I'm in no hurry to sell it so please keep all lowball offers to yourself. Please e-mail me at asmarrazzaq@msn.com if you're interested or if you have any questions.
Maintenances & Modifications:
- JDM ITR 4-1 header
- JDM ITR cat (passes emissions/smog)
- JDM ITR exhaust system
- New battery (replaced 2 month ago)
- New spark plug wires (replaced 4 months ago)
- New spark plugs (replaced 4 months ago)
- New timing belt (replaced at 85,000 miles)
- Phillips HID headlights (bluish/whitish colored)
- Sony MP3 deck (aux and USB connectivity)
- Tein S.Tech lowering springs
- Viper alarm system (2-way security system)
- Yokohama S.drive tires (90% tread left)
email sent, Asmar. Please contact me at drabbag@gmail.com
