Distributor Rotor Stuck on
Old Feb 28, 2014 | 06:37 PM
jglover's Avatar
Default Distributor Rotor Stuck on
And yes, i did remove the screw from the rotor. I have pulled and pulled but nothing. Is there a tool for this? I am still at the stage were I havent used screwdriver and I hope not to go there. Nothing to pry against. Any Ideas, please 97 Civic
Old Feb 28, 2014 | 06:59 PM
B_Swapped93's Avatar
Default Re: Distributor Rotor Stuck on
screw driver and pry against the edge there's a port you can fit a screw driver into the center.
This is one of the mani reasons I went with the coil on plug retro fit....hate those stupid distributers.
Old Feb 28, 2014 | 08:07 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
You could also try tapping the rotor mildly/softly with a hammer. It might shift it down onto the post a little bit breaking it free of the grip that is holding it, or maybe the vibration will knock it loose.
I do mean softly though. Don't want to shove the shaft into the engine with a swift beating. Tapping by some peoples standards can drive a 16 penny nail through a 2x4. That's too hard.
Another trick is to take a long shoe lace and wrap it around the base of the rotor a few times. End up with each end of the shoe lace or twine 180 degrees of each other and yank firmly and repeatedly. This is essentially the same as prying without putting any stress on any other part other than the rotor and then only in an outward direction.
Old Mar 1, 2014 | 05:54 AM
Former User's Avatar
Remove the distributor from your car and, on a work bench, carefully cut off the rotor with a Dremel-type tool.
Old Mar 1, 2014 | 06:22 AM
HondaPartsHero's Avatar
Technical Hero
http://ask-the-electrician.com/distr...-assembly.html
jglover's Avatar
Thanks TomCat39, RonJ and Parts Hero. We will see were this leads me today
Old Mar 1, 2014 | 01:11 PM
Eg.ls.turbo's Avatar
Use a flat head and pry on one side carefully and do same for other side of rotor.
Old Mar 1, 2014 | 05:37 PM
angrysmileyface's Avatar
Do as ronj says. Use a dremel cut shallow slots in the rotor collar and then using a screwdriver separate the slots with a twisting motion
Old Mar 2, 2014 | 06:01 AM
belairbrian's Avatar
As you probably noticed this is a fairly common issue. I prefer the dremel tool method. If you remove the distributor, make a mark across the distributor base and the block so you can align it to the same position when you reinstall it.
Street Ghost
Dec 19, 2023 04:31 PM
97SS
May 12, 2009 10:07 PM
Sir Kyle
May 10, 2008 06:30 PM
toooslow
Jun 11, 2003 11:20 PM
blackls
Jul 5, 2001 07:31 PM
