"Best" d16 cable tranny?
hey guys.
i dont know alot about d16 cable transmissions, i currantly have a 4 spd on my 88 ef hatch, i'm gonna install a vitara engine in soon so i want to look for the best 5 spd i can find,
how many 5spd cable trannys do we even have?
thanks
thanks
For your set up I would go with a D16 Si trans and add an MFactory LSD if it's in the budget. Only 88 has 21 spline main shaft, 89-91 has 20 spline shaft. You can use the 89-91 trans as long as you change the clutch to 89-91 too. The ZC DOHC models use a larger differential and only will fit with the ZC intermediate shaft and 2 equal length CV shafts. All SOHC USDM models use one long and one short axle (no intermediate shaft). You can use a ZC trans for the shorter gears in a USDM set up as long as you change the differential and axle seals.
These are the 1988-1991 L3/SL3 D Series cable transmissions I have seen... but there may be more.
4 speed: 3.89 ratio
5 speed: HF 2.95 ratio, HF 3.25 ratio, DX 3.72 ratio, DX 3.89 ratio, LX 4.06 ratio, Ex/Si 4.25 ratio
ZC 5 speed: 3.89 FD with close ratio shaft gears, 4.43 FD with USDM spec shaft gears, 4.43 FD with viscous LSD and USDM spec shaft gears.
4 speed: 3.89 ratio
Tranny guru's both of you!
Aquafina, stop by back on HB some time, trying to get a revival.
Half my GSR trans is filled with Synchrotech stuff!
I agree with both of them, thought we were talking OEM.
uvamosk
Jul 30, 2010 03:15 AM
Masta
Apr 29, 2008 02:38 PM
