93 civic ex start problem
Old Feb 28, 2014 | 10:37 AM
eric587's Avatar
Default 93 civic ex start problem
Hi I have a 93 civic ex and it will not always start sometimes it does others it doesn't,when I press on the gas and try it does work.when it does start it sometimes dies unless I give it gas, I think it might be a fuel problem but don't want to start throwing parts at it to fix, any ideas? Thank you
Old Feb 28, 2014 | 06:18 PM
eric587's Avatar
Default Re: 1993 Honda civic ex start problem
any ideas guys i searched couldnt find anything
Old Feb 28, 2014 | 06:50 PM
MOTORVATIONS's Avatar
Clogged fuel filter, weak fuel pump, faulty fuel pressure regulator. Without a fuel pressure gauge, you will not be able to test the regulator, but I would check the items listed above in the order in which they are listed.
Good luck.
Old Feb 28, 2014 | 08:17 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
^^^ Beat me to it for fuel filter as the first suggestion.
Was gonna ask, do you know when it was changed last?
Another question that might be relevant is do you know if or how many times the car has been driven till dry (driven till totally out of gas)? One or two times is detrimental for the fuel pump.
One thing the gentleman above me didn't suggest was clogged fuel injectors. When was the last time you ran a fuel injection cleaner? The one I'd personally recommend is Wynn's Power Charge. Wynn's product has been clearly demonstrated to clean carbon out of the fuel lines and injectors. Probably one of the best fuel system cleaners out there.
Then the other part to check test is of course the Regulator on the fuel rail.
Old Mar 1, 2014 | 06:00 AM
Former User's Avatar
Default Re: 93 civic ex start problem
  1. Clean the IACV and FITV. Click links in my signature.
  2. Any CEL codes?
  3. Last full ignition system tune up?
Pr0ject93hb
Feb 25, 2007 08:34 AM
RA12825
Jan 29, 2007 08:51 PM
dogbiscuit
Aug 30, 2005 11:45 AM
Magick211
Oct 30, 2004 10:28 PM
PUSHER
Jul 3, 2003 10:08 PM
