Clear CEL code without resetting ECU
Old Feb 25, 2014 | 05:54 PM
jodyboy's Avatar
Default Clear CEL code without resetting ECU
I have a code for downstream o2 sensor that I want to go away because I'm not going to replace it and I need to know if a CEL code pops up again.
All of the write ups on how to remove them involve resetting the ECU, which I can't because I'll lose my tune. 96 Civic y7
Old Feb 25, 2014 | 05:57 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Clear CEL code without resetting ECU
What kind of two cent setup do you have that you'll lose a tune if you reset your ECU?
Old Feb 25, 2014 | 06:02 PM
crazyhouse2011's Avatar
Buy a ******* obd2 scanner. I got mine for 40 bucks even though my car is obd1. They will remove that code.
Old Feb 25, 2014 | 06:03 PM
jodyboy's Avatar
I was under the impression that's what happened.
Old Feb 25, 2014 | 06:04 PM
jodyboy's Avatar
If I had money to throw around I would. but thanks.
Old Feb 25, 2014 | 06:07 PM
What tune do you have?? Stock ECU? We need some specs up in here.
Old Feb 25, 2014 | 06:12 PM
NotARaCist's Avatar
Yeah no, that's not how it works unless someone REALLY fucked up your wiring. Just reset the ECU.
Old Feb 25, 2014 | 06:14 PM
B_Swapped93's Avatar
if 40$ if too much, you need a new hobby sorry to break it to you
probably just a "chip" and even those you don't loose the basemap**, no ems that I know of goes lets the "tune" go away when you re-set the ecu.
jodyboy's Avatar
I honestly have no idea. I'm good with mechanical stuff, not eletrical. I don't even know if I could get any info on the tune. A friend of a friend did all of the ECU/tuning work for me a few years back.
Old Feb 25, 2014 | 06:17 PM
jodyboy's Avatar
I used to play around with my car a lot back in high school when I had lots of time/no bills. I'm just trying to get it back to running correctly now. And its actually kind of fun having to go through junkyards to find dirt cheap parts.
Old Feb 25, 2014 | 06:36 PM
slowpokecivic
Feb 20, 2007 04:59 PM
tz-devil77
Jan 21, 2003 12:37 PM
Lei Siew Long
Apr 24, 2002 09:27 AM
