Timing belt crank gear loose
Old Feb 25, 2014 | 03:24 PM
boostedteg4dr's Avatar
Default Timing belt crank gear loose
The gear on the crank for the timing belt seems to have a little play either direction. Its not anymore then a degree each way. might not even be that. is this normal?
Old Feb 25, 2014 | 08:25 PM
holmesnmanny's Avatar
should be no play i wouldnt chance it ... pull the gear and replace the key
Old Feb 25, 2014 | 08:39 PM
slowcivic2k's Avatar
Default Re: Timing belt crank gear loose
Remove the gear, and the wooddruff key. Inspect the pocket that the keys rests in.
j4s0n1337
Feb 15, 2012 03:07 PM
Svery
Feb 8, 2010 01:21 AM
jjipson
Dec 4, 2009 05:00 PM
H22AJSPEC
Jul 16, 2003 07:38 PM
blufke
Mar 6, 2003 11:40 PM
