p28 injector drivers smoking
Hey HT, i have a p28 5speed obd-1 ecu that was previously chipped and socketed. I cut the j1 jumper to revert back to stock like i read in some other threads, but after doing so, the injector drivers started smoking after about 30 seconds. i shut the car off so i wouldnt fry the drivers. the vehicle is a 1994 civic ex model. motor is a d16z6. Previous motor was a built lsv setup, but he put stock motor back in
My questions are,
1. should i get a new ecu as this one is possibly damaged or get new injectors?
2 is there something else i should check out before i swap anything out
3 should i continue to remove chips and capacitors?
not sure if the current injectors are saturated or peak and hold. i know peak and hold you would need a resistor box and can damage the ecu if you dont run one.
car ran fine with the ecu chipped but was just super rich so i want it back to stock. last owner had a built lsv motor with 310cc injectors
Hope i provided enough information. thanks in advance guys
My questions are,
Doesnt make sense how there was no smoke prior to cutting the j1 jumper.
UPDATE: buddy of mine took chip, socket, and resistors out and injector drivers still smoke. going to check resistance in the morning
UPDATE: didnt want to wait til morning and not be able to sleep. now i definatly wont sleep cuz ill be wondering wth to do but injector 1 read 12.0 ohms injector 2 read 11.9 ohms injector 3 read 12.1 ohms and injector 4 read 12.2 ohms.
so from my knowledge i have the correct injectors. saturated injector run anywhere between 10-15 ohms while peak & hold run in the 1-4 ohms range. thinking i may need a new virgin p28 ecu.
also noticed that the alternator plug was changed from the green round plug to the square canadian plug. would that make a difference or even matter?
UPDATE: was going through the harness today and found that the wires on top of the Oxygen sensor are frayed and in bad shape so i swapped out with an old one i had laying around. ECU doesnt smoke but now im getting a code 41 which is primary oxygen sensor. im getting a denso sensor later since everyone says bosch dont last long.
also, would having the j12 resistor cut in the ecu affect anything?
mycrx7
Jan 8, 2007 11:07 AM
