Steering Rack replacement options
Old Feb 25, 2014 | 08:52 AM
sumdewd's Avatar
Icon2 Steering Rack replacement options
Getting sick of my rack end bushing clunk that won't go away no matter how many times I replace suspension parts. I have already tried ebay 'rebuilt' racks just to have the thing clunk as soon as I install it. I've even replaced the bushing in the new rack to have it clunk in a month flat.
Anybody have experience with buying an advance auto/Autzone rebuilt steering rack? Or 'new' ones off of ebay? Is there an aftermarket/performance rack worth its salt for daily driving?
I have a 90 Si hatch and I don't need/care for the variable rack. Any input is appreciated
Old Feb 25, 2014 | 10:10 AM
Tyson's Avatar
Default Re: Steering Rack replacement options
Are you adjusting the pinion gearbox?
Old Feb 25, 2014 | 10:23 AM
sumdewd's Avatar
Yes sir. I have the rack adjustment tool and I tightened the 14mm bolt until I felt resistance, then backed it off 1/8-1/4 turn. Helped a whole lot with the steering wheel play, not so much for the clunking.
Old Feb 25, 2014 | 10:30 AM
Freemananana's Avatar
Does it clunk while it turns? Is that the symptom? Or always clunking?
Old Feb 25, 2014 | 10:43 AM
sumdewd's Avatar
Only over roads with light and wavy bumps. It sounds like a very light knocking chatter coming from the front passenger side, almost like tapping a fingernail on a wood table with moderate force.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/rack-end-bushing-keeps-exploding-3069529/
This was my post almost 2 years ago with the back story. I'm dead sure it's dirt and grit sanding down the rack end bushing from buying a bad ebay rebuilt rack. I've just finally gotten sick of it again to start thinking about buying a brand new rack, not a rebuilt one.
Any input on whole replacement racks? I am looking at a 'new' one on ebay for 200$.
Edit: I saw somebody replied on my old post about getting the new ebay one. Can anybody tell me if the new ebay ones last more than a year or two? I just want to set the car up and forget about it.
Old Feb 25, 2014 | 03:29 PM
Tyson's Avatar
Try a new rack then. Your current one may be out of service limits, not cylindrical or bent even. So the plastic bushing can't do much to fix that.
I doubt you really feel the variable difference in the Si rack. But you can try a closer ratio rack from quaife.
I'd be curious to examine your old rack once its out. Lay it out on a flat table or straight edge and see if you see light.
dubyas1989
Mar 17, 2013 07:54 AM
mflannery1980
Feb 24, 2012 10:03 AM
Mohsin
Oct 7, 2008 01:56 PM
CivicHB93JDM
Sep 8, 2005 09:00 AM
Andy Hollis
17
Jul 28, 2004 06:04 AM
