Locking up rear brakes on track, proportioning valve recommendations please
Old Feb 24, 2014 | 03:59 PM
90civichbsi's Avatar
Default Locking up rear brakes on track, proportioning valve recommendations please
I just went out to the track this weekend after adding better pads and fluid and bigger MC. As I started pushing the car deeper into the braking zones the rears started locking up a little bit.
What would the next step down from a 40/40 proportioning valve be? 90-91 CRX si 2040? or 90-91 Civic EX 3540? Any other recommendations?
I found this in a search (thanks Tyson), but I'm still not sure which one would be the best step down in rear brake bias: http://www.norcalcrx.org/tyson/pics/brakepartslist.gif
Current brake/tire setup: 90 civic si, integra rear disk swap, 4040 valve, 15/16 MC, Hawk DTC 30 pads front and rear, brembo blank rotors, motul 600 fluid, goodrich ss brake lines. 205/50/15 Falken ZE-512 which are being replaced with Direzza ZII this weekend.
This car is primarily driven on track and occasionally to work when the weather is nice.
Old Feb 25, 2014 | 04:51 AM
BLU CIVIC's Avatar
Track Advocate
Default Re: Locking up rear brakes on track, proportioning valve recommendations please
you may want to just use regular pads in the rear. At least that was what I was told by a lot of people, some running in Honda Challenge. Said a too aggressive pad would lock up the rear.
My set-up: DA front/rear disc, DA MC and booster, blank rotors, Carbotech XP8 pads in the front and BrakeBest pads in the rear, ATE Type 200 fluid, Techna-Fit ss brake lines
Old Feb 25, 2014 | 10:12 AM
Tyson's Avatar
You didn't up your front brakes?
Old Feb 25, 2014 | 04:44 PM
No, since I still drive the car on the street every once and a while I didn't want to go with anything more the DTC 30's up front. The next step down for hawk pads was the HP+ and I didn't think those would be enough.
Wouldn't lowering the rear bias with a different prop valve fix the issue?
Old Feb 25, 2014 | 05:19 PM
BLU CIVIC's Avatar
Track Advocate
rear pad is too aggressive. lowering the bias is, in effect, doing the same thing as using a less aggressive pad. if you're stuck on changing the mc,i believe there is a thread in the track forum
Old Feb 25, 2014 | 07:30 PM
I'm certainly not stuck on changing the prop valve and I understand the reasoning on using a different pad f/r. I was just curious if anyone else had considered using a different prop valve than a 4040 and kept the same pads front and rear with similar bite and temp characteristics.
From all of my searches I couldn't find any info relating to the actual differences in bias between the different valves but I suppose I'll keep looking.
Old Feb 25, 2014 | 08:57 PM
slowcivic2k's Avatar
Your rear pads are applying too much friction, or your front not enough. You can fix this by either increasing the front brakes or reducing the rears to a point.
The proportioning valve works by engaging the rears after a certain amount of pressure applied to the front brakes is breached in the valve itself. Poor telemetry could also be a cause.
Are your rear wheels leaving the ground? What is the condition of your suspension? Suspension is often overlooked, and without it your brakes will flounder.
Old Feb 25, 2014 | 09:18 PM
BLU CIVIC's Avatar
Track Advocate
https://honda-tech.com/forums/showth...rtioning+valve
Old Feb 26, 2014 | 01:16 AM
Tyson's Avatar
theres no prop valve that is used in a system with regular front brakes, and rear disc brakes.
its really no surprise your system is all wrong.
Old Feb 26, 2014 | 06:01 PM
Tyson, I appreciate your responses to the thread, but the last part of this it quite unnecessary and unconstructive. Back when I did the rear disk swap in 2003 the 4040 valve was the only thing people used on any EF/ED when doing the swap. I am looking to improve my current setup and seeing if a different prop valve could be a solution.
It looks like the closest setup to mine is the 90-91 CRX Si's although they have a slightly larger front caliper piston & rotor. The 2040 may be a better option for my current setup but may not solve the issue.
BLUCIVIC I have read through those 2 threads you posted previously and there is a lot of great info. Although it looks like the actual bias of the various prop valves is still unknown.
I'll be seeing how the car reacts with the new tires soon and go from there. I may play around with different prop valves on the track to see what happens. Otherwise I may try my old axxis metal master rear pads and rotors or step up to the DTC60 up front for track days.
Old Feb 27, 2014 | 04:48 AM
BLU CIVIC's Avatar
Track Advocate
change the rear first since you already have it parts
Old Feb 27, 2014 | 07:46 AM
Tyson's Avatar
its very constructive and relevant.
you added more brakes to the rear. youre complaining about rear brakes locking up first.
whats the surprise???
Old Feb 27, 2014 | 07:58 AM
4drEF's Avatar
Keyboard Humorist
My $0.02
The prop valve from the CRX Si that came with rear brakes is as close as you could get to matching your current brake setup.
Every stock prop valve is biased for street use and the rears will lock up before the fronts in hard braking.
Good braking for normal stops, but not very balanced for occasional hard braking with weight lifted off the rear end.
Different pad compounds in front and rear are your friend.
Old Feb 27, 2014 | 09:03 AM
For sure, that is the plan after the new tires. The pads/rotors still have enough life left in them to at least try it out. Thanks!
Old Feb 27, 2014 | 09:09 AM
My point is that all your slightly jaded responses to this thread came with a hint of attitude that isn't needed to get the point across.
I also never complained, in fact the slight lockups made for a fun drive around the track, albeit not the fastest or safest. Thanks to responses I know what I'll be doing and will probably end up with a set of track and street pads. No harm done in my book.
Enjoy the rest of your week.
Old Feb 27, 2014 | 03:27 PM
Tyson's Avatar
this is not true.
you never want the rears to lock up before the rears. street or track.
http://www.stoptech.com/technical-su...alance-matters
in fact, i have anecdotal evidence that there is a max relief pressure so the rears dont lock up. (as long as the rest of the system is as close to designed of course.) im pretty sure its part of the double pair of numbers code in the honda prop valve numbering, but not done enough testing to make a final statement.
Old Feb 27, 2014 | 03:45 PM
4drEF's Avatar
Keyboard Humorist
^ that is right on a stock brake setup.
My comment was in regard to his rear setup. No stock prop valve is going to solve his issue.
Old Mar 1, 2014 | 05:50 AM
So it turns out I still have the old rotors but threw away the pads when I was cleaning the garage. Which pads do you recommend I get for the rear?
Think the HP+ would be too much? The only turn I know that I was locking up on was a flat trail braking turn coming off of a straight so the issue isn't too severe.
Also, I think I may just step up to the 10.3" front brakes when these front pads wear out.
Old Mar 3, 2014 | 08:57 AM
BLU CIVIC's Avatar
Track Advocate
i'd spend $20 at autozone for some rear pads. if you want Hawks, get their street pad
Old Mar 4, 2014 | 07:04 PM
ef2_civic's Avatar
Nice post. Makes me think of my set up and willow springs coming up too
GABOCRX
14
Apr 7, 2016 07:46 PM
heeltoego
13
May 21, 2012 03:35 AM
TodaSi
Aug 20, 2002 04:20 PM
JeffS
10
Aug 6, 2002 10:55 AM
