Civic (eg) to Integra (dc) suspension questions
Here's what I got goin on. I have a 93 coupe and just pulled the front suspension (hubs, knuckles, discs, calipers, upper arms) and rear (trailing arms, upper and lower arms, discs, calipers, and ebrake cables). It's an 01 so it had abs. I pulled all the sensors off of the suspension front and back. My question is can I use the proportioning valve off of his car? As my car lacks abs. And should me swapping all of the abs suspension and brake parts be ok? Thanks for any input.
You'll need the prop valve, master cylinder and brake booster from a '94 - '97 RS (non-abs) you can use the rest of the stuff though.
So I can't use the master cylinder off of the abs car? And where is the brake booster located? Thanks for the response and advice.
The brake booster is the big round bowl like thing the master cylinder is attached to.
The reason you can't use the the one you just got of the Integra is the brake lines are a larger size and it's a big nightmare. And trying to use the brake lines from the Integra is an even more impossible nightmare with bending lines and all kinds of crap if it's even doable. If you get the one 94EG8 mentioned it all bolts up with your existing brake lines.
Another Drew
Jul 4, 2005 06:35 PM
rukawa1one
Sep 18, 2003 05:25 PM
saber1
Nov 11, 2002 11:09 PM
