SK - CAN 96' Turbo H22 Civic Hatchback FS- 375HP Laskey Built *
Old Feb 21, 2014 | 06:48 PM
drummer0940's Avatar
Default 96' Turbo H22 Civic Hatchback FS- 375HP Laskey Built *
96 Civic hatchback (street or strip). sleeved stroker 2.4L H22 EK hatch. Stage 2 turbo kit. Built by Laskey Racing 3 angle machined head longblock (VTEC) engine (universal iron ductile sleeve)
built & tuned by professionals .
Universal ductile Iron Sleeve by Dan Benson. block work by team Laskey Racing (California )
car tuned for premium pump gas (ONLY Vpower)
made 375HP/302ft lb on pump gas & Yes whp not crank...
build will support much more as is running 11psi .
Car mint-has NO rust NO paint chips NO cracks & car exactly as seen in pictures. Body has 75xxx ORIGINAL KMs.
Fully built H22a cylinder head
ARP headstuds
o/s valves
valve springs
adj cam gears
ACL bearings
Crower retainers
ARP wheel studs on front too
Custom Valve cover
RC engineering 68mm throttle body
Mugen Port/polished h22 intake manifold
Hondata manifold gasket
2.4L stroker block;(benson sleeved)
F20 crank polished and balanced w/full bottom end build
H22 CP pistons (JE 8.6:1)
H spec Pauter Rods & Rings
Built with all new honda parts:
new oil pump -water pump -timing belt .Also New battery,
Blueprinted bottom end &balanced ..
$8000 spent on block work alone (receipts from Laskey Racing)
Have have the tuning map file for car
5500km on complete build (& that's nothing first 2000km were break in)
Turbo Setup(stage2):
Turbonetics Turbo t03/t04E (.57 AR Comp)
Revhard FMIC
Vortech BOV
Turbosmart 35mm wastegate
Full turbo kit ($3000+ alone )
dual stage manual boost controller (has boost solenoid for electronic boost control)
Revhard Intercooler
Drivetrain:
built H trans($1000 between this and the clutch)
ACT extreme 6 puck upgraded unsprung clutch
ACT pressure plate & extreme flywheel
Custom Axles
Diffs have been changed to full front toque biasing diff : Qualife LSD was $1000.
Fuel/ecu :
Speedtech tune (Calgary Brad Unryn)
Hondata s300 ECU
Aeromotive FPR
Walbro 255lph pump
RC 850cc injectors ($500)
PLX r500 wideband (interior usb panel for tuning) ($700)
MSD digital 6 ignition
modifications/parts :
Full custom 3” Magnaflow exhaust
Racing Hart EVO 17”rims( were $1100 alone w/tires)
new BFG rubber all around
CF hood ($700)
Omni Threaded Coilovers ($850)
KVR python 4 piston calipers (fr)
Disc swap rear
Cryoslot rotors
Type R front grill/rear lip/spoiler
Carbon Fibre Front Lip
Mugen strut tower bars front/rear.
Susp tech front/rear sway bars
Comp engineering front end traction bar setup
Cross beam and adjustable radius rods.
Other:
manual tensioner mod (new oem honda parts)
car has 2 step launch control w/pyrometer &gauge installed (4000set rpm 8200 is redline)
Balance shaft removal modification (saves 8lbs) by Laskey
Custom crank work by Dan Benson
Interior:
Red Recaro Millennium Front Seat(like new -no rips wear or tear)
Custom Upgraded upholstery
Momo steering wheel with leather wrap
Boost gauge, pyrometer Gauge and temp Gauges
Pioneer head unit(wired for subs)
Compustar 2 way alarm/starter
SIR Gauge Cluster with JDM Bezel
Fr/ Rr JDM Fog Lights
Fr Fender Side Markers
Glow Boost & Air Fuel/Volt Gauge Apexi
JDM Cup Tray Holder
Momo Type R Shifter, Boot &****
also has unique Red Honda emblems..
Fwd street car- no toy it ran 11.1sec(slicks) 1/4 mile @124 mph)
*This civic is a great example of a well built, fast, clean vehicle that many strive to build. Here it is at the fraction of the price.
Serious buyers only will be allowed to see car.
no junk only quality parts used in build
One of a kind & must be seen
Has extensive build list
Meticulously maintained and built.
Won't find one built boosted & tuned for less.
Not parting out
NO LOW BALLERS- I am in no rush
Most Recent maintenance also includes both master and slave clutch cylinders were replaced with new OEM honda parts & pro steel line installed
Parts alone on this car equal to more then I'm selling for!
Every single detail or mods been documented& can be provided upon request
My loss-your gain
Serious inquires only-Make me an offer-legit trades considered
located in Regina
$9000 OBO
Any questions contact:
306-550-1521
Old Feb 21, 2014 | 07:25 PM
turnsignalandy's Avatar
Default Re: 96' Turbo H22 Civic Hatchback FS- 375HP Laskey Built *
dear lord, wtf happened to the interior?
Old Feb 23, 2014 | 03:13 PM
its all the dash was redone and painted. looks just like new*
Old Mar 1, 2014 | 09:40 AM
For those not familiar Here is a little review
Old Mar 1, 2014 | 09:41 AM
Old Mar 2, 2014 | 06:07 PM
semitas's Avatar
much respect for such a maticulous and basically perfect build! and a hell of a deal at that price
Old Mar 25, 2014 | 07:30 PM
Thank you
Old Apr 6, 2014 | 12:02 PM
up cars still for sale came out of storage this weekend
drummer0940
Canada (Sales)
Jun 1, 2014 04:02 PM
drummer0940
Canada (Sales)
Apr 6, 2014 12:00 PM
jdmrenzo
Dec 8, 2009 11:34 PM
ranta18
61
Apr 15, 2006 01:02 PM
