sleeved H22 turbo honda civic hatchback
testing watersne in a kind EK. makes 375hp on lowboost. fs; my 96 ' Civic hatchback (street or strip). sleeved stroker 2.4L H22 Built by Laskey Racing with a 3 angle machined head & full longblock (VTEC engine w/ Stage 2 Turbo Kit.) has universal iron ductile sleeve.5600km's
built & tuned by professionals .
Universal ductile Iron Sleeve by Dan Benson. block work by team Laskey Racing (California)
car tuned for premium pump gas (ONLY Vpower)
made 375HP/302ft lb on pump gas & Yes whp not crank.
build will support much more as is running 11psi .
Car mint has NO rust NO paint chips NO cracks & car exactly as seen in pictures. Body has 75xxx ORIGINAL Kilometres
Fully built H22a cylinder head
ARP headstuds
o/s valves
valve springs
adj cam gears
ACL bearings
Crower retainers
ARP wheel studs on front too
Custom Valve cover
RC engineering 68mm throttle body
Mugen Port/polished h22 intake manifold
Hondata manifold gasket
2.4L stroker block;(benson sleeved) -
F20 crank polished and balanced w/full bottom end build
H22 CP pistons (JE 8.6:1)
H spec Pauter Rods & Rings
Built with all new honda parts:
new oil pump -water pump -timing belt .Also New battery,
Blueprinted bottom end &balanced ..
there over 10 grand under the hood alone. not to mentioning time or labor. has alot of money spent on block work alone (receipts from Laskey Racing)
Have have the tuning map file for car
5600km on complete build (& that's nothing first 2000km or so were break in)
Full turbo kit Setup(stage2)($3000 alone )
Turbonetics Turbo t03/t04E (.57 AR Comp)
Revhard FMIC
Vortech BOV
Turbosmart 35mm wastegate
dual stage manual boost controller (has boost solenoid for electronic boost control)
Revhard Intercooler
Drivetrain:
ACT extreme 6 puck upgraded unsprung clutch
ACT pressure plate & extreme flywheel
Custom Axles
Diffs have been changed to full front toque biasing diff : Qualife LSD ( was $1000 alone.)
Fuel/ecu :
Speedtech tune (Calgary Brad Unryn)
Hondata s300 ECU
Aeromotive FPR
Walbro 255lph pump
RC 850cc injectors
PLX r500 wideband (interior usb panel for tuning)
MSD digital 6 ignition
modifications/parts :
Full Custom 3” Magnaflow exhaust($1000 alone)
Racing Hart EVO 17”rims
new BFG rubber all around
Omni Threaded Coilovers ($900)
CF hood ($700)
KVR python 4 piston calipers (fr)
Disc swap rear
Cryoslot rotors
Type R front grill/rear lip/spoiler
Carbon Fibre Front Lip
Mugen strut tower bars front/rear.
Susp tech front/rear sway bars
Comp engineering front end traction bar setup
Cross beam and adjustable radius rods.
Other:
manual tensioner mod (new oem honda parts)
car has 2 step launch control w/gauge installed (4000set rpm )
Balance shaft removal modification (saves 8lbs) by Laskey
Custom crank work by Dan Benson
Interior:
Red Recaro Millennium Front Seat(like new -no rips wear or tear)
Custom Upgraded upholstery
Momo steering wheel with leather wrap
Boost gauge, pyrometer Gauge and temp Gauges
Pioneer head unit(wired for subs)
Compustar 2 way alarm/starter
SIR Gauge Cluster with JDM Bezel
Fr/ Rr JDM Fog Lights
Fr Fender Side Markers
Glow Boost & Air Fuel/Volt Gauge Apexi
JDM Cup Tray Holder
Momo Type R Shifter, Boot &****
also has unique Red Honda emblems..
Fwd street car- no toy it ran 11.1sec(slicks) 1/4 mile @124 mph)
price is open to best offer.
keeping in mind there is well over 18k into the complete build.(/time/labor)
possible entertaining trades
4x4 truck
or car- / + cash
not really opening up to much more unless you have
a newer seadoo or arctic cat snowmobile.
Any questions call - text
306-550-1521
*This civic is a great example of a well built, fast, clean vehicle that many strive to build. Here it is at the fraction of the price. My loss is your gain
no junk only quality parts used in build
One of a kind & must be seen
Has extensive build list
Meticulously maintained
Won't find a cleaner 96EK.
NO LOW BALLERS am not in a rush
- car cant be built for less.
**Most Recent maintenance includes new axle & pro steel line installed.
both master and slave clutch cylinders were replaced with new OEM honda parts &
Every single detail & mod has been documented & can be provided.( i have paperwork from build)
located in Regina
Serious inquires only
* unless cash in hand otherwise i will be giving the 'test drive'
ARP headstuds
o/s valves
valve springs
adj cam gears
ACL bearings
Crower retainers
Custom Valve cover
Revhard FMIC
Vortech BOV
Revhard Intercooler
Drivetrain:
Custom Axles
Fuel/ecu :
Hondata s300 ECU
Aeromotive FPR
Walbro 255lph pump
RC 850cc injectors
CF hood ($700)
Disc swap rear
Cryoslot rotors
Other:
Interior:
JDM Cup Tray Holder
4x4 truck
or car- / + cash
306-550-1521
located in Regina
drummer0940
04-06-2014 12:02 PM
drummer0940
Canada (Sales)
04-06-2014 12:00 PM
