00 Civic EX puffs at low speed and rough idle
HI, my honda civic 2000 puffs at low speed, and CEL flashes. A jump plug shorting abs reading shows the following codes (pretty bad I guess). Any suggestion where I should start to look? Thanks a bunch..
12 EGR - exhaust gas recirculation lift valve
16 Fuel injectors
18 ???
54 CKF - crank fluctuation sensor
61 Primary oxygen sensor
16 Fuel injectors
18 ???
Head gasket, spark plugs (oem is best), ignition wires. Egr valve and 02 sensors of what i don't know. Bump
Maybe buy an helms manual and get the whole thing straight.
Last edited by TomCat39; Feb 21, 2014 at 08:10 PM. Reason: Almost seem to post just to up post count. Please use edit button.
it's 2000 civic ex, has 180K miles on it. spark plugs/wires, distribution caps etc replaced at 150K. should i try to replace the fuel filter? not sure when that last replaced.
Thanks.
Thanks.
How to check head and block engine codes? I see the following below the ECU: 1214-286797
Also coolant level is fine.
Also I just changed gas filter and no help
You have an ECU for the D16Y8 engine (Civic EX). This ECU should never throw an EGR code. Reset the ECU to clear the codes, and then run the engine and recheck the codes.
https://honda-tech.com/forums/showpo...5&postcount=12
SalsaGuy
May 3, 2017 04:41 PM
nismoracingsx
23
Feb 18, 2014 04:32 PM
corpsebesideme
16
Dec 4, 2011 11:40 PM
derjac
May 24, 2010 01:46 PM
