Finding correct AC bracket for '94 Sol w/B18A1
Hey all! I have a '94 Del Sol, originally with a B16, which I dropped a B18A1 ('93) into. The motor came with mounts for accessories and the alternator, power steering, etc. all fit, but the bolt pattern for the A/C compressor is different. Can someone point me in the right direction for getting my compressor bolted on?
This is the bracket I'm referring to:
If your del sol is original b16 just swap the a/c bracket.
If is d series and d compressor you need the 93-97 sol VTEC or CRV a/c bracket.
Unfortunately I don't have the B16 that was originally in it. It's the right compressor for a B16 though.
If I buy an OBD1 B16A3 A/C bracket, will it definitely bolt onto my B18A1 block?
Yes if it is from a sol, If this is the original sol A/C compressor you need the bracket to bolt in the b series block but with D series compressor pattern.
93-97 VTEC sol
97-01 CRV
Both use b series engine with D series A/C compressors.
93-97 VTEC sol
97-01 CRV
I suppose I'll be wanting one that looks more like http://www.ebay.com/itm/AC-Bracket-B-Series-Engine-Swap-Civic-Integra-B16-B18-Air-Compressor-Mount-EG-DC-/230701910748?pt=Motors_Car_Truck_Parts_Accessories&hash=item35b6e7cadc&vxp=mtr than like http://www.ebay.com/itm/JDM-B20B-A-C-AlUMINIUM-BRACKET-SUITS-CIVIC-INTERGA-B-SERIES-B16A-B18C-B16B-B18B-/271251579020?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f27daa08c&vxp=mtr? Some have pulleys and some don't.
EDIT: Some quick Google-fu suggests that there are a ton of different brackets that should fit on a B18, but I need to get the original bracket which would've been P30, as there are a few different compressor bolt patterns too.
The black one is what you need.But first contact the seller, there's a little mistake in the add. If it fit 92-00 civics with b series using the oem compressor it will not fit integras. Also you need the adjuster Assy.
The second one is JDM and specify to be used on b engines with b compressor.
No.....The p54 mount is the correct mount for b engine/d compressor or the crv mount
P30 was b/b like the p72
forcfedcivic, You know the 3 of them carry the same First five numbers and the three last ones the only different are the middle ones but are the same.
quote. Just walk up to the parts guy and say you need 38930-P54-000 (94-95 Del Sol VTEC) or 38930-P30-000 (96-97 Del Sol VTEC/Civic Si) or 38930-P7J-000 (CRV)
P54 = sol vtec 93-95
p30 = sol vtec 96-97
pj7 = CRV
http://www.oemacuraparts.com/parts-c...engine-mount-1
pj7 = CRV
'99 - '00 Si is definitely stamped P30, but uses a regular B-series compressor, if '96 - '97 Del Sol is the same you'll need a '94 - '95 Del Sol Vtec bracket or '97 - '01 CR-V.
The P30 is for b motor b compressor.....it will not work on b with the d compressor
The P30 is from 99 si.....which uses a b series compressor
The ONLY mounts that will mount to a b series motor AND use the d series a/c compressors are the p54 and the crv p7j.
mgrcrx
Jan 16, 2014 03:45 PM
jdmvtecej2
Sep 7, 2008 01:39 PM
RCautoworks
24
Jul 25, 2005 03:58 PM
