D15B timing issues this morning :(
Old Feb 21, 2014 | 06:27 AM
94civiccpe's Avatar
Default D15B timing issues this morning :(
Helping my friend finish his motor and I can't seem to get every thing lined up correctly. I figured ive done this enough times by now but I guess not.
D15B- Using a VX Belt and water pump a Z6 tensioner. I took pics from different angles. It looks pretty close but after I turn a complete rotation it looks slightly more off.
Old Feb 21, 2014 | 06:33 AM
94civiccpe's Avatar
Default Re: D15B timing issues this morning :(
Just wanted to point out that if I line up the 7 O CLOCK the 9 and 3 O CLOCK lines do not line up perfectly with the arrows on the timing case.
I thought I time this just like the Z6 with the 7 O CLOCK line? Heres that it looks like after turning it 3 teeth and tighting tensioner and 1 complete rotation.
Old Feb 21, 2014 | 07:15 AM
94civiccpe's Avatar
Im super confused now.. I did a lot of searching and found this info from a diff site.
"Setting timing: You set the timing on the cam gear as you would on on a D15z1--using the TDC indicators that parallel to the head with the "UP" facing up. You do not use the timing indicator on the 7 o' clock position of the cam gear. Just to be on the safe side when checking timing, use a long rod and stick it inside the number one cylinder to make sure you are actually at TDC. "
Well do I time it like a z1 or the z6?
Old Feb 21, 2014 | 07:49 PM
94civiccpe's Avatar
Tried a diff belt still no GO.. couldnt figure it out I dont understand so many mixed thoughts on set ups.
Old Feb 21, 2014 | 08:30 PM
Former User's Avatar
JDM D15B engine? If so, which one?
Old Feb 21, 2014 | 08:56 PM
94civiccpe's Avatar
Its the OBD1 just D15B regular Vtec I believe it has 1 vtec solenoid and it the head is stamped the same as a d16z6.
Old Feb 22, 2014 | 03:49 AM
94EG8's Avatar
Seagull Management
Use the 7 o'clock pointer on the timing cover. It looks good in first couple of pics, but then after it's tensioned it looks like it might be off a tooth. Sometimes it's hard to tell though.
Old Feb 22, 2014 | 08:00 AM
The OP is using a D15Z1 timing belt. Does he need a D16Z6 timing belt?
Old Feb 22, 2014 | 10:12 AM
94EG8's Avatar
Seagull Management
It should ok, really I've heard you can run a Z6 belt when using the Z6 tensioner, and that a VX belt might be tight, however using one or the other doesn't affect the timing.
Old Feb 22, 2014 | 10:29 AM
94civiccpe's Avatar
Still have not for it right yet lol. Vx belt. Z6 tensipner
Old Feb 22, 2014 | 10:43 AM
Old Feb 22, 2014 | 03:59 PM
94civiccpe's Avatar
Ive tried every way I could think of still no go lol. IDK haha. Its either 1 tooth off backward or 1 tooth off forward cant get it exactly lined up.
mthibode
May 25, 2016 05:51 AM
ixlr8ez
Dec 2, 2006 11:25 PM
tianporn
Jul 1, 2006 11:08 PM
menappi
Feb 17, 2005 10:40 PM
