94 Del Sol randomly stalls
Old Feb 20, 2014 | 01:50 PM
skeyser's Avatar
Icon6 94 Del Sol randomly stalls
Vehicle is my son's "learning" car. We know the car was involved in some sort of accident because it has a salvage title. As title states it randomly stalls. It hasn't done it while I have been driving the car, but stalls with my son.
The IAC was replaced.
New battery installed. My son initially installed the battery backwards and blew the battery relay, but we replaced it and the car ran okay for awhile.
Fuses have been checked (per FAQ) they are all good.
Initial no start was traced to coil (no spark).
>Plugs were replaced (they were OLD) and new rotor for dizzy.
>Second no start was traced to ignition module (no spark) and new dizzy cap.
>Third no start fuel pump wasn't engaging. Check fuses, bench tested main relay, jumped terminals to power fuel pump, k-tested ECU and replaced ECU. >Also cleaned and tightened FIT valve and reset idle and compression tested cylinders.
>Bench tested MAP sensor (has power, ground and drops voltage when vacuum is applied)
When the car runs it sounds better than when we bought it.
The problem is that it randomly stalls. Upon trying to start the fuel pump does not kick in, but if we plug and unplug the MAP sensor it will start right up.
As an side note the SRS light is continually on and will not reset. I don't think these two issues are related.
Any suggestions?
rdh2059
Jun 9, 2024 01:26 PM
Robert Watson
Aug 9, 2017 09:23 PM
rhkinkoph
Apr 20, 2014 01:57 PM
Mothgoul
Oct 3, 2011 05:08 AM
t4tejas
Apr 30, 2008 02:27 PM
