need help with ecu problems
Old Feb 19, 2014 | 03:37 AM
jdmjunior1991's Avatar
Default need help with ecu problems
so basically i picked up a 99 ek coupe with a b20b4 in it the motor is obd2a and the ecu is obd2b. i found a obd2a p2e ecu could i just use that one and it will work? and what kind of harness would i need or would it just be easier to get a jumper harness?
Old Feb 19, 2014 | 03:46 AM
Fliptard's Avatar
Default Re: need help with ecu problems
A P2E ecu will not work as it is a Single cam ecu. It may run the motor, but not correctly. What ECU is in the car now? you could just buy an ECU jumper from OBD2b chassis to OBD2a ecu
Old Feb 19, 2014 | 03:58 AM
the ecu in the car is the factory 99 civic ecu a obd2b
Old Feb 19, 2014 | 04:00 AM
but if i got a jumper harrness it would need to be obd2b to obd2a correct? as the motor is obd2a
Old Feb 19, 2014 | 04:01 AM
Fliptard's Avatar
you could just run an LS P75 ECU, whether, and get a jumper if it's OBD2a like I stated before. OR you can go on a site like www.phearable.net/ and get an OBD1 ecu with a B20 base map, and convert your motor to OBD1
Old Feb 19, 2014 | 04:41 AM
what obd is the p75?
Old Feb 19, 2014 | 04:47 AM
i actually think i will just order the ecu than you for your help
Old Feb 19, 2014 | 05:26 AM
HondaPartsHero's Avatar
Technical Hero
You'll want a 96-99 integra p75 with a jumper harness as the 00-01 P75 has the immobilizer if you plan on staying OBD2.
Old Feb 19, 2014 | 02:39 PM
do you think a p72 would work?
Old Feb 19, 2014 | 02:41 PM
but then id need to take care of the vtec huh hmmmmmmm
Old Feb 19, 2014 | 02:44 PM
Technical Hero
No it'll throw codes for VTEC, knock and just isn't tuned for the B20. I believe you can also use a 99-01 CRV manual ECU as well.
Old Feb 19, 2014 | 02:53 PM
thank you for your help im going to try and source a p75
Old Feb 19, 2014 | 06:03 PM
another question please help. i have everything i need becides this wiring stuff. so if my ecu is obd1 and my motor is obd2a i need to get a harness for the ecu to obd2a correct? do i need another harness for the engine to the ecu? or the distributor? just very confused on all this please help
Old Feb 20, 2014 | 01:30 AM
Technical Hero
Are you going to use an OBD1 ECU? If so you'll just need the OBD2B to OBD1 ECU adapter and the OBD1 P75 ECU and you'll be done.
Old Feb 20, 2014 | 04:04 AM
yes i am trying to source a p75 ecu and ill wait until i get one to get it all put together just seems it would make more sense to do it that way rather then try to cut a corner. im guessing when you said obd2b you ment obd2a? and by adapter you meen jumper harness correct thank you again for your help saves me a headache ive done most the research myself i just want to make sure i get the correct ecu and wiring.
Old Feb 20, 2014 | 05:40 AM
kyden's Avatar
a p75 can be obd1, obd2a, or obd2b.
To run an obd1 p75, you'll need an obd2b to obd1 jumper harness.
Old Feb 20, 2014 | 10:20 AM
ok so i think im starting to under stand all this now the jumper harness more or less just plugs into the ecu correct? and since the original ecu is obd2b i would need a jumper harness from that to whatever obd my ecu is?
theres a wire that connects to my distributor that i think i would need to source some kind of new one not really sure so i will take pictures now and post
again thank you
Old Feb 20, 2014 | 11:29 AM
again thanks for help as this is my first swap (we all have to start some where)
i think one of them is called the ivac? not to sure and im not really sure what the other one is either and some one said it might be easier if i just get a ls intake?
Old Feb 20, 2014 | 08:58 PM
Old Feb 21, 2014 | 01:17 AM
Technical Hero
The distributor connector won't be plug and play. You're going to need to rewire the connectors or use an adapter harness. The black plug by the intake manifold post the wire colors because it could either be the intake air temp sensor or the EVAP purge plug. The round sensor on the intake manifold is the IAT sensor and you'll either have to swap to a round connector or use your current cars intake sensor and drill a hole in your intake arm to make it work. For any other connectors you aren't sure about post the picture and the wire colors.
Old Feb 22, 2014 | 04:54 PM
sorry been working alot and havent had the time to do this will get it done tommrow when im off
thanks again
Old Feb 25, 2014 | 11:00 AM
i apologize again to anyone following or helping me on this thread i work monday through friday 12:00 midnight to 8:30 and its kickin my ***. but i have been doing a little more research when i got free time and would a pr4 ecu work? and i am going to for sure get these pics posted tommorow sometime or today if i still cant pass out lol
Old Feb 26, 2014 | 10:50 AM
i took a picture of everything that wasnt hooked up and i ordered a p75 ecu and got the jumper harness
Old Feb 26, 2014 | 10:55 AM
Old Feb 26, 2014 | 11:11 AM
also the harness coming off the distributo has 9 pins but looks like its missing one. the one going to it has 8 i looked on rywire and they only have 10 pin to 8 pin am i missing one or do some come with 9?
