Remove Aftermarket Tachometer Help
Old Feb 18, 2014 | 02:58 PM
95_DB7's Avatar
Default Remove Aftermarket Tachometer Help
I have a '99 base and the person I bought it from installed an aftermarket tachometer which I'm not liking at all. Also, he installed reverse glow gauges that I would like to remove as well. So my goal is to remove the aftermarket tach and the reverse glow gauge cover.
I've searched and searched but I can't find anything regarding un-installing the aftermarket tach. What steps do I take? What tools do I need?
Thanks in advance!
Old Feb 21, 2014 | 09:16 AM
95_DB7's Avatar
Default Re: Remove Aftermarket Tachometer Help
I got the glow gauges off now I just need help removing the aftermarket tach. Can anyone direct me where I need to go?
Old Feb 22, 2014 | 02:42 PM
TheJGB3's Avatar
How about some pics of it. Where is it mounted? where the stock one was? on the column? on the dash? does it have a shift light?, etc.
Old Feb 25, 2014 | 08:50 AM
95_DB7's Avatar
Here is a pic. No shift light. It doesn't even light up so I can't see it at night.
[IMG][/IMG]
Old Feb 25, 2014 | 06:31 PM
crazyhouse2011's Avatar
I would leave that in there. It's hellaJDM
Old Feb 25, 2014 | 06:45 PM
Lugzilla's Avatar
Canuckian
It's most likely screwed into the a pillar cover. Unscrew it, then remove the a pillar cover. There's a few clips holding it on, pry very gently as these are easy to break, best to do if its warm. Trace the wires from the aftermarket tach to where they are connected and cut them off. Remember to wrap up any exposed wiring when you're done.
Old Feb 25, 2014 | 07:15 PM
ph1l1pp3's Avatar
just remove it and remove wires.... not that hard,. signal, ground and power.....
miamirice
Jun 2, 2011 02:13 PM
Subwarrior
Jan 1, 2005 09:46 PM
GTlvr82
18
Mar 21, 2003 02:23 PM
civicracer1993
Jan 25, 2003 04:03 PM
Vteg02
Jul 26, 2001 03:44 PM
