b16 idle problem
Old Feb 18, 2014 | 01:24 PM
Maxman's Avatar
Default b16 idle problem
I have a 94 civic with a b16 swap after it gets warm it idles up and down from 700 to less than 500 and it dies sometimes. It idles up and down in gear or out of gear. I've checked for air in the coolant and I found some but it still idles the same. There was a hose missing that goes to the throttle body I replaced it but it didn't seem to help. I also checked the IACV but it looked pretty clean. I don't know what else to do.
Old Feb 18, 2014 | 02:02 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: b16 idle problem
Pull and clean the IACV as well as the FITV. Once you've done both of those things, bleed your coolant again. Is your CEL on? Does it work?
Old Feb 18, 2014 | 02:10 PM
Maxman's Avatar
The cel isn't on. When I turn the key on it lights up for a second so I'm assuming it works.
eg6noise
Aug 19, 2017 12:01 PM
k2day
Nov 19, 2011 09:38 PM
andyc_0652
Oct 18, 2010 11:37 AM
jarvis199
Sep 15, 2005 06:26 PM
hybridbmw
May 8, 2005 01:58 PM
