96 civic sedan front lower contorl arm bolt???
Old Feb 17, 2014 | 03:19 PM
Boss727's Avatar
Default 96 civic sedan front lower contorl arm bolt???
The bolt in the pic i noticed when changing my rotors and pads , that it will not tighten all the way. Its very loose.tried tighting it and it just spins. Would it be cause the bushing is bad? Help would be apprecited
Old Feb 17, 2014 | 03:23 PM
B_Swapped93's Avatar
Default Re: 96 civic sedan front lower contorl arm bolt???
There's 4 bolts in that pic....mind saying which one ? either way either the threads on the bolt are stripped or the nut or both.
Boss727's Avatar
Dont know if pic workes
Old Feb 17, 2014 | 03:24 PM
Boss727's Avatar
Far right one under cv boot..
Old Feb 17, 2014 | 03:45 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Check the back side of the bolt. Quite likely it has a welded nut and the weld has broken free allowing it to spin freely and not tighten.
Old Feb 17, 2014 | 04:07 PM
Boss727's Avatar
Ya already tried looking at the back nit the piece (idk wht its called) that it bokts to u csn only see the bottom of it. Its closed in tha back
Old Feb 17, 2014 | 04:14 PM
your tierod boot is ripped you'll want to replace that more then likely a stripped nut if there's some bolt still sticking out put a 2nd nut on for the time being, I've done that in the past till I got it replaced/fixed.
Old Feb 17, 2014 | 05:50 PM
Boss727's Avatar
Thats wht ill do, thanks guys.
Old Feb 22, 2014 | 05:01 AM
Boss727's Avatar
Anyone know the size nut #19 is?
Name:  1320810277-hardrace 6122-A diagram.jpg
Old Feb 22, 2014 | 05:45 PM
It's a M10 iirc
Old Feb 22, 2014 | 06:03 PM
NotARaCist's Avatar
I never narc'd on nobody!
NUT, SELF-LOCK (12MM) (CLINCH)(SATO RASHI)
It's an M12.
drsab2000
10
Mar 23, 2013 02:28 PM
Dann6968
11
Jul 15, 2012 07:19 AM
brandon43
Jul 18, 2009 11:41 PM
Setsuna F Seiei
May 12, 2006 09:15 PM
SC0TT
Jul 23, 2003 05:21 PM
