Honda CR-V & Element 2WD & 4WD Element & CR-V
I have an idea
Old Feb 17, 2014 | 01:53 PM
civiceg94's Avatar
Default I have an idea
I was brain storming at work. Would a wrx work rear diff work for our crv and then have our crv awd ? Just need to check if the rear diff ratio would spin at the same rate or could switch out the rear diff to match. Lets everyone brain storm.
Old Feb 17, 2014 | 02:40 PM
theycallmedj's Avatar
Default Re: I have an idea
good info, hope someone can find something out
Old Feb 20, 2014 | 04:59 PM
PhilStubbs's Avatar
Anything can be done with enough cutting and welding, but why would you want to?
Old Feb 20, 2014 | 05:19 PM
civiceg94's Avatar
Its just a though because our "AWD" suck. It kicks in when it wants to. When you could use a diff that runs full time AWD. And also use lsd in them.
Old Feb 21, 2014 | 03:26 AM
PhilStubbs's Avatar
If that's what you are after, there are many more options than the wrx. Look into the ford 8.8 irs diff. You can get ring and pinions for those to get any gearing you want.
Old Feb 21, 2014 | 05:37 AM
civiceg94's Avatar
If you look at the how the wrx diff looks compare to the crv they almost look the same so it might be less work. And weight compared to a diff from a ford. its justed a though out there am not really trying to drop big money i dont have.
Old Feb 21, 2014 | 06:16 AM
dogbiscuit's Avatar
I know theres some mods out there to make ours engage more often. you can maybe check into that first and see how much you like that before you drop more money into something else.
Old Feb 21, 2014 | 06:51 AM
civiceg94's Avatar
I seen that mod it was to engage it quicker. But still going to suffer from being an open diff. For people that like taking the crv offroad i think a diff like the ford or wrx might be nice.
Old Feb 22, 2014 | 08:43 AM
noname87's Avatar
i don't know what kind of offroading you're doing that you don't think the crv's are that capable because i've tried to get mine stuck and i haven't been able to. i would think as long as you could get the correct gear ratio in the suby rear end to match the honda trans then it would be fine once you got it mocked up
Old Feb 22, 2014 | 09:54 AM
civiceg94's Avatar
I did a slight offroading in my old 1st gen with toyo open country at2 and the thing sucked. One wheel spin and the rest didnt do anything in some little sansy spot while the others were on hard dirt and no i didnt drive fast in that spot. i dont believe much the crvs are much capable offroaders. I could say that my 2 nd gen feels a little more improved then the 1 st gen
Old Feb 22, 2014 | 12:50 PM
NZ-DB8R's Avatar
You will need to fit a WRX center diff as well, ever driven a proper 4x4 with diff lock? Tried driving it on the road with the diff lock engaged?
It doesnt work because all wheels are turning at the same time so you cant turn very well, it crab walks and ruins your tyres and driveline.
Old Feb 22, 2014 | 01:25 PM
civiceg94's Avatar
Yeah my old civic had a crazy lsd in it. Why would it need a center diff if you just need the drive shaft from the crv going straight to the rear diff.
Old Feb 22, 2014 | 02:43 PM
NZ-DB8R's Avatar
Why does a WRX have a center diff? Because it needs it.
My friend has a WRX STi Type R with controllable Center diff, it specifically says that locking the center diff (same as not having one at all) is only for gravel use. Doing it on tarmac WILL destroy the driveline
Old Feb 22, 2014 | 03:14 PM
civiceg94's Avatar
So how about just using a regular wrx rear diff. Or use what philstubbs said a ford 8.8 irs that would be nice. So who here has won lottery to put hese plan into action lol
Old Feb 22, 2014 | 03:37 PM
lol
Old Feb 22, 2014 | 08:34 PM
NZ-DB8R's Avatar
I dont think you have really grasped how a 4x4 drivetrain works, ALL WRX have a center diff, as do all Mitsi Evo etc
What you want to do is this
"system has to be engaged manually once you were on a loose surface because they “locked” the inputs of the front and rear differentials together making turning difficult on high traction surfaces. Engaging AWD on pavement could result in damage to the systems, or at the very least strange road manners"
What it needs to do is this:
"The system used a lockable center differential that allowed the front and rear axles to spin at different rates on pavement allowing the system to be engaged at all times. The system was designed with off-roading in mind, so the transfer case had a low range like like the rugged truck based systems at the time in addition to the full-lock feature."
simplex
Transmission & Drivetrain
Jan 3, 2018 05:45 PM
Unjockable
10
Jan 1, 2004 09:44 PM
skribblah
16
Jul 2, 2003 09:47 AM
io_burn
Apr 29, 2003 01:43 PM
