Transmission & Drivetrain Gearboxes, Differentials, Clutches
reverse not the same after opening case.
Old Feb 17, 2014 | 02:28 AM
First.EG's Avatar
Default reverse not the same after opening case.
Hey guys so I had a pretty big leak coming from the two half's of the transmission LS trans by the way. I open it up reseal it and what not put it back in the car and reverse doesn't go in how it used too. Let's say that before the shift lever would drop in to gear 2 inches and now it only goes in half an inch.
All other gears are the same and it doesn't grind in reverse. is this something I should be worried about?
Old Feb 17, 2014 | 05:28 AM
Emeraldbomber's Avatar
Don't be shy. Sometimes it needs some force.
Old Feb 17, 2014 | 11:54 AM
First.EG's Avatar
Default Re: reverse not the same after opening case.
That's the thing man I tried slamming it in reverse and it won't go any further. it does go in to gear I just find it odd that it's like that now.
Old Feb 17, 2014 | 01:29 PM
Is the linkage binding? Banging off anything? Shifter bushings? Bitch pin in tight?
Old Feb 18, 2014 | 04:25 AM
94EG8's Avatar
Seagull Management
Did you line up the 5th/Rev stopper plate before you put everything back together?
Old Feb 18, 2014 | 06:33 AM
^ good call I totally forgot about that.
Old Feb 18, 2014 | 12:30 PM
First.EG's Avatar
O man I didn't know I was supposed to do that. It was my first time opening a transmission looks like I'll have to open it again to check that.
windupwagon
Feb 5, 2018 07:17 AM
95islegreensol
14
Feb 3, 2018 01:41 PM
naftaliz
Oct 2, 2017 08:13 AM
m.glisson003
May 17, 2013 01:50 PM
mojord
13
May 21, 2002 08:08 AM
