Oil level issues
Old Feb 15, 2014 | 02:18 PM
DjDoc6's Avatar
Default Oil level issues
Ey guys im having a slight issue. Last week my dip stick showed i had zero oil. Not a drop on the stick! And that was after my car was sitting for two hours. I needed to change my oil pan gasket anyway so i droped my oil pan and there was atleast 2-3quarts in the pan. Left me a little conffused. Anyway i changed the gasket and oil filter and out in 4 1/2 quarts of oil in the car. Its been 4 days i decided to check my dip stick and there is just a little on the stick right below the first circle. Im so confused i know im not leaking 4 1/2 quarts of oil.
Engine : B18C5
Old Feb 15, 2014 | 02:19 PM
DjDoc6's Avatar
My buddy also have a b18c5 in his car i looked we have the same size oil pan and same size dip stick. Im really mind fu*k3d on this
Old Feb 15, 2014 | 03:14 PM
DjDoc6's Avatar
Anything?
Old Feb 15, 2014 | 04:16 PM
preludeNApower's Avatar
Default Re: Oil level issues
My friend, the stick does not go to the bottom of the pan. The bottom of the stick usually indicates ABOUT 2 quarts low.
Old Feb 15, 2014 | 04:18 PM
Miguel613ekb18c's Avatar
Ur probly burning oil the by piston rings or valve stem seals if ur not leaking though your oil pan or main seal
Old Feb 15, 2014 | 05:43 PM
DjDoc6's Avatar
I know im leaking a little at the PVC but in four days i dont believe i could have burned two quarts or leaked two quarts thats a **** ton.
I replaced the dizzy o ring becuase i was leaking there. Oil pan gasket, valve cover gasket, cam seal.
Old Feb 23, 2014 | 06:50 PM
How many clicks have u driven in 4 days, I've seen Hondas burn oil until there's no oil left on the dip stick 500 km of driving
Old Feb 24, 2014 | 05:44 PM
98vtec's Avatar
moderator emeritus
this is the engine management and tuning section. you posted in the wrong section.
this is for tuning software help and engine computer help.
Old Feb 24, 2014 | 05:46 PM
98vtec's Avatar
moderator emeritus
the top mark represents full. the bottom mark represents 1 quart low.
Uljima
Jun 3, 2015 06:17 AM
bjones6215
Sep 10, 2013 07:55 PM
tw1nny03
Mar 3, 2008 05:29 AM
uEDarkShadow
Jul 13, 2006 07:02 PM
swlabhot
Aug 21, 2003 04:38 AM
