Can this B16 be repaired or should I buy a replacement?
Old Feb 13, 2014 | 08:27 PM
05foresterxt's Avatar
Default Can this B16 be repaired or should I buy a replacement?
I've own a couple of Hondas in my time, including two EM1s. Currently I deal mainly Subarus. One of my EM1s I sold to my brother in law. He loves the car and has had it for many years. Recently he had an issue with the water pump failing. He took it to a shop and they did the timing belt at the same time as I suggested as well.
Well, the shop didn't do a great job at re-installing the crank pulley. They forced it on with an impact gun probably and the crank/pulley look to be damaged.
Good news is that the shop are repaying him back from their insurance. He most likely get $3,000 dollars, what the dealer quoted for the repair.
I have not seen the engine, but here are some pics he sent me. So, the big question, can this be repaired so he can keep the cash or should he look at a replacement engine and part out the existing? Should he stay with the B16 or upgrade to the B18? If upgrading, what else would he need to upgrade?
Old Feb 13, 2014 | 09:57 PM
crazyhouse2011's Avatar
Default Re: Can this B16 be repaired or should I buy a replacement?
Well if their insurance claims it was a 3000 dollar job, take that 3 grand and pay the shop to do the work right. And make it clear that they are to torque everything to spec.
Or you could take out the B16, put in a B18C5 for around that price, maybe a little more, and sell the B16 for a couple hundred at least.
Your call
Old Feb 13, 2014 | 10:34 PM
The shop is giving the money since they are located a couple hundred miles away. He was visiting family when this happened.
I'm also wondering if rebuilding his original engine would be cheaper as well.
Old Feb 14, 2014 | 12:56 AM
Marvin1985's Avatar
Get another crank or new motor/ecu.
Old Feb 14, 2014 | 03:22 AM
94_civic_dx's Avatar
i agree with marvin get another motor i would go with a ls or b20 and put the vtec head on and go from there and get some mods with the extra cash
Old Feb 14, 2014 | 05:08 AM
tony_2018's Avatar
Fish Twig
Wow...well at least they're paying for it and not hiding from there mistake. To make life easy he can just swap in another b16, just make sure its an obd2b engine. Saves time from swapping over parts so thats less labor and more money to go towards all the seals he's gonna wanna replace while the motor is being swapped in. The internals should be fine if he bought it from a legitimate company.
Old Feb 14, 2014 | 05:11 AM
Fliptard's Avatar
get a new crank, use he extra money for whatever else you want.
Old Feb 14, 2014 | 05:17 AM
tony_2018's Avatar
Fish Twig
You're not looking at it clearly, I can understand because the pics are dark.
Old Feb 14, 2014 | 06:06 AM
kyden's Avatar
not looking at what clearly? the keyway is sheared. new crank is needed.
Old Feb 14, 2014 | 06:10 AM
94EG8's Avatar
Seagull Management
I fixed one of those for myself a few years ago, get a new/good used crank pulley, key and bolt. Clean up the end of the crank, put the crank pulley on and slide the key into position, grind down a small finishing nail so you get get it started, make sure you cut it down so it's a little shorter than the key, hammer it in, put the bolt in with a good impact gun with some loctite on the threads. Mine never came back out again. I wouldn't do it for someone as a professional repair, but it usually will work, worst case it doesn't work and you still need a new crankshaft.
Old Feb 14, 2014 | 06:11 AM
You can do a complete rebuild on that engine and transmission for about that price. It would in essence reset your mileage to zero on the engine and tranny. Think about that...
Old Feb 14, 2014 | 07:19 AM
Thanks guys for the options.
My brother in law is really not a car guy, so he wants the less troublesome solution. He wants to keep the same engine as well for the same reasons.
I've given him the option of just buying another used engine, but then the risk of the engine being old/bad and eventually failing again comes into play.
I've also given him the option to just replace the crank and do a rebuild on the engine. What are some reputable engine builders in CA?
Old Feb 14, 2014 | 08:47 AM
tony_2018's Avatar
Fish Twig
Just because you rebuild the motor doesn't mean the tranny will have zero miles too........
Old Feb 14, 2014 | 08:49 AM
tony_2018's Avatar
Fish Twig
hmotorsonline hasn't failed me, and seems to be in the west coast area. I would suggest jdmtiger as well, I know I read bad reviews but for the last 3 times I ordered a motor it has not failed me at all.
Old Feb 14, 2014 | 09:13 AM
I'll check out hmotorsonline. The transmission is fine, not grinding or anything. Someone is selling a B16 locally, but wants 1200 bucks.
Old Feb 14, 2014 | 12:01 PM
hmotorsonline doesn't have any usdm b16a2 motors.
Old Feb 14, 2014 | 01:24 PM
tony_2018's Avatar
Fish Twig
Check around for more shops in your area that sell jdm motors. If they do installs let them do it as well that way they can't say you or your installer fucked up.
Edit: I found this, http://www.nippon-motors.com/prices/honda/. obd1 longblock for 950. Just swap over some parts, you're gonna do maintenance on all seals and stuff so it shouldn't matter. Swap over the oil pump and the CKF sensor, the timing belt cover will fit as well ( I know because I took it off my b16a2 and swapped it onto my jdm high compression b20b).
Built4Battle
Dec 23, 2013 01:57 PM
kuja
Jun 9, 2005 07:11 AM
