B16 crank pulley/timing question
I'm sure it's been covered before but everything I searched didn't give me sufficient enough answers.
I know that the b16 crank pulley is smaller than LS and gsr.
And I have a complicated question an I'll try to make as much sense as possible.
So let's say you run a b16 block with LS or gsr crank pulley and if you use the line/marks on the cam gears, crank pulley and timing belt cover to do your timing would that be accurate timing since the b16 pulley is smaller ?
Thanks.
Thanks.
wunfstgsr
Jan 27, 2009 08:28 PM
importboi22
Mar 5, 2004 08:55 PM
pokemon
May 20, 2003 08:38 AM
