Is my ecu fried?
Old Feb 12, 2014 | 10:51 PM
bigmaccrew's Avatar
Default Is my ecu fried?
I have a 97 civic ex with h22a jdm swap and a p75 chipped ecu. Recently my speedo quit functioning and now the car won't rev past 3500 rpms. There was a cel code 9 but was a loose wire in harness but now there's no cel and it still won't rev past 3500 rpms. Wondering if my ecu is fried and how I could check it or if maybe there's another explanation. Thank you
Old Feb 13, 2014 | 06:37 AM
Miguel613ekb18c's Avatar
Default Re: Is my ecu fried?
Check vtec clean it may be clogged
Old Feb 15, 2014 | 03:06 PM
VegasInvasion's Avatar
I'm Huge In Japan
A clogged vtec solenoid will not cause limp mode, this is a crank sensor problem regardless if the code is gone. First of all, check every fuse.
You can check if your ECU is fried by using another ECU. There's no other way.
99% of the time, code 9 is caused from bad wiring. I guarantee you still have a wiring problem, or a faulty ground. Especially because it's an H22 swap, which never comes without at least one issue.
Do a proper wire continuity and short check, try another ECU, replace the distributor.
Old Feb 21, 2014 | 08:40 AM
92cxturbo's Avatar
Do you have 2-step setup on the ecu? If the speedo stopped wotking, and the ecu is not getting a signal from the vss, you make be stuck in 2 step mode.
Old Feb 21, 2014 | 12:57 PM
WhyTease's Avatar
He says it's a JDM H22A, doesn't that mean it doesn't have a crank position sensor or cam position sensor?
I had this problem, as well with my F20B. I used a chipped ECU and it wouldn't rev past 3,500RPM. Plugged in an OEM H22A ECU and it ran fine.
Then I started having misfire problems at the same RPM, the VTEC plug wiggled out.
Old Feb 21, 2014 | 01:09 PM
pennies_hatchie's Avatar
vtec plug wouldnt have anything to do with misfire. If it's unplugged, vtec just wouldnt engage.
to OP, if speedo doesnt work, i would check the vss, the vss sensor, or wiring. if it wont rev pass 3500, then you're in limp mode. check the CEL to see what the issue is. usually its the distributor.
Old Mar 11, 2014 | 02:10 PM
I'm Huge In Japan
All Hondas including the JDM H22A use all three position sensors. Some engines have a fluctuation sensor, but the P75 doesn't check for CKF.
Old Mar 24, 2014 | 10:49 AM
larios2281's Avatar
Fix your speedometer or get the 2-step removed
Old Apr 6, 2014 | 09:05 PM
rob.p's Avatar
I had the same problem I had s300 with coil on plug setup went to get tuned wouldn't rev past 3500 just dumped fuel. swapped s300 for chipped p28 on the spot. worked fine. try a friends ecu if same problem check wiring harness for loose wires and go from there.
Old Apr 11, 2014 | 06:02 PM
zachhthe1's Avatar
I had a similar issue with my old chipped p06. Does sound like your in limp mode. My advice to you is definitely find some way to swap your ecu with a different one before you go tearing into your dizzy. I did the dizzy before the ecu swap test and lost some valuable time. Do a decent visual inspection of your dizzy wire plugs for damage or green corrosion. Check all your grounds in the engine bay as
Old Apr 13, 2014 | 10:41 AM
asady191's Avatar
VegasInvasion is right. Check for continuity.
Old Oct 7, 2018 | 07:42 PM
Aj92hatchback's Avatar
I have a 92 hatchback with a obd2 gsr & harness that runs fine on a stock p28 but when I plug my S300 witch is in a p28 the car just fries it any answers?
Old Oct 7, 2018 | 08:20 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The car fries what ??? The ECU ??? If so, separate the s300 and the ECU and try them independently and see which part is the problem.
dookiebox
Engine Management and Tuning
Jan 29, 2013 03:44 PM
danteisme
Nov 2, 2007 02:25 PM
WhiteDSM520
Jan 24, 2005 10:34 AM
Blaze45
Feb 21, 2004 08:15 PM
kim_2_da_chee
May 30, 2003 06:18 PM
