Suspension & Brakes Theory, alignment, spring rates....
Looking for the Brake Expert
Old Feb 12, 2014 | 12:34 PM
THC07's Avatar
Default Looking for the Brake Expert
I remember reading a post from the Brake Expert that explain'd in detail why doing OEM rear disc conversion on our civic dose not improve the stopping distance in our civics an integras. can anyone help me find it or link me to it? TIA
Old Feb 12, 2014 | 01:04 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Looking for the Brake Expert
Stickied thread in the brakes section. BrakeExpert's Brake Chart Thread - Civic Brake Upgrades for EF, EG, EK and Integras
Drum to Disc Conversion - Side notes on the conversion
The most common upgrade people want to do to their EK is put disc brakes on the back because they stop better, and have less nose dive than drums. Now drums do last longer, but if you want better stopping, go with discs. Also, please read about brake bias before you decide if you want to put discs on with the stock 9.5" front brakes if you have bad tires. Many will attest that discs with the stock DX front brakes causes the rear brakes to lockup first. This may be true with non-performance tires and on a track, but on the street under normal braking, you will be fine.
I don't have a DIY up yet on my rear disc conversion, however there are may written with better pictures, so I will just leave a few notes.
First off, MAKE sure you bleed it untill there are NO air bubbles. Your car doesnt drive if it doesn't stop. Acquire all your tools and a torque wrench. Now a note; the e-brake cable is hard to get out of the drum assembly. You want to hit the hubber along the e-brake cable with WD-40, and inside the drum assembly, is a spring clip. Its got 6-sides. Slide a box end 13mm wrench over the end of the e-brake cable, and slide it firmly over the end of this clip, and it will compress, so you can firmly pull the cable out the other side. Another note, is that once the trailing arm is attached, undo and redo each bolt, torque properly, when the car is sitting on its own wheels, so the bushings arent overstressed all the time cause there binded more than expected (not the trailing arm's center bushing).
Old Feb 12, 2014 | 01:17 PM
THC07's Avatar
damn i must have looked right past it. ty
Old Feb 12, 2014 | 03:01 PM
Kozy.'s Avatar
a.k.a. Komodo
I'm not sure if that's what he was asking for?
Syndacate
88
Jun 19, 2006 11:33 AM
Crx_Civic
Apr 25, 2006 11:11 AM
RedlineShftr
Feb 11, 2005 02:59 PM
B18C_EJ8
May 19, 2004 02:48 PM
