1996 Prelude H22A Burnt wire issue
Old Feb 10, 2014 | 08:25 PM
Lugnutz1987's Avatar
Default 1996 Prelude H22A Burnt wire issue
Just to run down I've had an issue with wiring burning up. To start The negative lead coming off the battery burnt up. When this happened I replaced the negative battery lead, battery, starter" Starter shorted out" and caused the negative lead to burn up and it killed the battery. Now that I've replaced all of that, 6 wires coming off the harness burnt up they are ylw/blk and blk/ylw and I have no clue what it goes to or why it burnt up. I could really use some help on this one[IMG][/IMG]
Old Feb 10, 2014 | 09:07 PM
Default Re: 1996 Prelude H22A Burnt wire issue
All these problems started after the clutch swap could there be an issue that happened after the clutch install?
Old Feb 11, 2014 | 04:41 AM
integra_101's Avatar
Didnt properly hook up your ground wire that bolts onto the transmission housing?
c|rop3asy==[]
Sep 9, 2013 11:17 PM
jc95148
11
Dec 21, 2012 08:53 AM
jc95148
Audio / Security / Video
Dec 20, 2012 06:42 AM
Mr. Giggles
Oct 31, 2006 12:20 PM
graphic
Dec 9, 2003 07:17 PM
