cold lower radiator hose?
Old Feb 10, 2014 | 02:04 PM
crazyhouse2011's Avatar
Default cold lower radiator hose?
I just got home from a 50 mile round trip, doing 70 mph at 3100 rpm for the last 20 minutes. I pulled into my drive way and felt my coolant hoses. The upper hose was very warm to the touch (but not burning me), and the lower hose was cold just like outside. I felt my way up the hose until i was close to the thermostat, and it was kinda warm there. The coolant gauge was reading a hair or two below halfway, so normal temp. But why is my lower radiator hose so cold when the upper one is hot?
I feel like it's a problem with my thermostat.
D16z6, 5 speed, 95 honda civic EX, etc etc.
Old Feb 10, 2014 | 02:42 PM
Default Re: cold lower radiator hose?
Also, i forgot to mention that the heat works just fine, and the coolant is full. The hoses to the heater core are hot as well.
Old Feb 10, 2014 | 02:53 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
If the lower radiator hose is cold, it means the thermostat did not open yet.
Old Feb 10, 2014 | 03:04 PM
It's below zero outside, so maybe the radiator is cooling the coolant really well? I was doing interstate driving after all, and my radiator fan does turn on in the summer...
Old Feb 11, 2014 | 04:26 AM
Boss727's Avatar
mine does that too. As long as it's not overheating of overcooling, don't worry about it.
Old Feb 11, 2014 | 04:32 AM
Schister66's Avatar
Man U FTW
My car has been doing this a lot lately too...it barely warms up, even after my 25 mile commute each morning. Today with the heat on, it barely registered half of what it normally reads on the temp gauge, but the heat still kinda works... it was -14F this morning
Keep an eye on it. When it warms up, check again and see if its still acting up
Old Feb 11, 2014 | 05:53 AM
No my heat was blasting hot, no problems there, and my temp gauge read just below half. As soon as i pulled in the driveway i popped the hood to check so the hoses didn't have time to dissapate heat. The lower hose was cold, and when i squeezed it i could hear sloshing noises, so i know there's coolant in it.
Old Feb 11, 2014 | 07:54 AM
ej1b18c1's Avatar
Being below zero outside does play a role. It's being air cooled while the thermostat is not opening because the thermostat is not getting 180 degrees to do so. If concerned just get a new thermostat and gasket, even oem is around $30-40.
Old Feb 11, 2014 | 09:30 AM
I don't have AC so the airflow to the engine block is much greater, so maybe your right.
Old Feb 11, 2014 | 09:49 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I wouldn't fret, the aluminum block and head are really good heat conductors, so when it's cold out, it runs cool, especially with the air flow of freeway driving. During winter, my rad fan never kicks on ever, thought it was broke until summer rolled around and I finally noticed the idle dip of it kicking on.
As long as your guage doesn't go high are stay forever low, you are fine.
My Honda Tech friend told me during winter it can take over 20 minutes to have the fans kick on when doing the cooolant bleed procedure.
Old Feb 11, 2014 | 11:02 AM
Former User's Avatar
Originally Posted by TomCat39
I wouldn't fret
This^
The thermostat doesn't fully open until the engine temperature reaches 194F. When the weather is very cold, the engine temperature may not rise quite this high, but will still be hot.
Joseprz
14
Aug 25, 2009 05:05 PM
aj_scribble
Mar 20, 2008 10:28 AM
TypeR0186
Dec 4, 2004 01:40 PM
TypeR0186
Dec 3, 2004 09:16 PM
Import Tuna
May 19, 2004 05:12 PM
