97 del sol driver side wheel
Old Feb 9, 2014 | 06:33 PM
alex2423's Avatar
Default 97 del sol driver side wheel
Hey all,
I have been having issues with my driver side wheel not spinning properly. Right now, I can drive the car fine but it feels like I'm going slower than usual. On 2 very cold days, the wheel completely seized and would not spin. Looking for any help possible, can't find an answer to this.
Old Feb 9, 2014 | 07:01 PM
OmarR's Avatar
Default Re: 97 del sol driver side wheel
Inspect the brake caliper. Sounds like it's seized from your description.
Old Feb 11, 2014 | 09:05 PM
alex2423's Avatar
Looked at it and it's not seized, also checked axle, bearings, and they were good but I had to force the rotor to move. Buddy I know said it might be warped.
Old Feb 11, 2014 | 09:24 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
If it's warped you should be able to feel it when driving, especially when you brake.
If you don't have any vibration when cruising or pulsing in the pedal when braking then it's more likely a stuck caliper piston like OmarR was eluding to.
Old Feb 12, 2014 | 03:01 PM
belairbrian's Avatar
This is how I would attack this.
jack up front end and remove wheel, place car in neutral
First look for something stuck between rotor and backing plate, might have kicked something up in there
next, remove brake caliper if wheel turns freely the problem is in the brakes
if that doesn't fix it, you probably need to disconnect the half shaft. At that point you can really check the wheel bearing, if it turns freely you have a really bad CV joint or a transmission problem.
jonstaub2011
Mar 22, 2011 05:00 PM
RedRevolver
Jan 13, 2009 03:07 PM
jit01
Apr 21, 2008 10:21 AM
ahloung
Northern California (Sales)
Mar 12, 2006 09:41 PM
JDM_SOHC
Oct 20, 2005 05:47 PM
