1995 VTEC Power Steering Leak - Ok to just remove the belt to drive?
Old Feb 9, 2014 | 03:08 PM
caliskier's Avatar
Default 1995 VTEC Power Steering Leak - Ok to just remove the belt to drive?
Hey I am getting parts in to repair a leaking pump. Getting foam in the PS bottle and overflowing, looks like the pump and maybe the lines are leaking probably pump seals need replacing. Any problem with just removing the belt to drive for a week while I wait for the parts to come in the mail?
Actually It may be off for a few weeks due to my very busy upcoming schedule.
Just wondering if I can drive for say 700 miles without a PS belt
Old Feb 9, 2014 | 03:12 PM
holmesnmanny's Avatar
its going to be a bitch to turn ... wouldnt risk it
Old Feb 9, 2014 | 06:25 PM
integra_101's Avatar
Default Re: 1995 VTEC Power Steering Leak - Ok to just remove the belt to drive?
You can do it. it wont leak anymore because there is noting turning the belt.
Old Feb 10, 2014 | 07:30 PM
caliskier's Avatar
That's what I thought, wanted to make sure nothing gets damaged.
Old Feb 11, 2014 | 07:03 AM
snobordboy's Avatar
Moderator
It will be fine, just remember that you will need to cary more momentum into low speed turns and parking, and it will build arm muscle a bit.
I frequently pull the belt on mine, and turning it with slicks aired down to under 15psi can be fun!
Many people have pulled most of the sytem and looped the lines with no ill effects, or gutted the rack to make steering easier, but it can give a vague wandering feel some have reported after gutting the rack.
Old Feb 11, 2014 | 10:06 PM
I had my ps belt come off using my accord pump with my h22a and I'll tell you it was quite scary. Good luck if you choose to go without it.
cory27
K Series
Apr 3, 2017 07:50 AM
mclasser
May 24, 2015 10:26 PM
turbotime
May 27, 2006 04:54 PM
Kyles ej1
12
May 15, 2005 05:33 PM
VTECRaZeR
Jan 27, 2004 10:59 AM
