Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
K24 into 8th gen civic ?.
Old Feb 9, 2014 | 01:57 PM
B_Swapped93's Avatar
Default K24 into 8th gen civic ?.
Looking to move onto another project this time around I'd like to get a base model civic and swap a k24a2 block with a k20z3 head(that way I can avoid the lack of a throttle cable issue the TSX uses). My question is it the same deal as swapping one into an RSX ? or would I be better off getting an RSX base and putting the k24 into that. I know the 90's Honda's inside and out and have plenty of tools/time but no too familiar with the new cars.
thanks.
Old Feb 10, 2014 | 01:35 PM
Eskimo253's Avatar
Default Re: K24 into 8th gen civic ?.
i have fg1 and it looks like it is a tight space went and looked at a rsx base model looks like more room in engine bay so i would say rsx would be easier
Old Feb 14, 2014 | 12:52 AM
vladd's Avatar
There are more differences between the Si and lower trims than just the engine and tranny. Just off the top of my head, I know that the subframe, front knuckles, and steering racks are different. You'd be better off finding an Si with a blown motor to swap the K24 into.
Swapping a K24 into an RSX would be a lot easier than swapping one into a non-Si 06+ Civic.
Old Feb 16, 2014 | 09:11 AM
Yah I was reading a bit more and that seems to be the case and I'm finding RSX's for cheaper then the new civic's.
Old Feb 16, 2014 | 09:27 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
OP, 06+ civics have no throttle cable, just like a TSX. Idk why you'd need a whole head to get rid of a throttle cable either....maybe I'm not understanding the intent.
Also not sure what room has to do with it? The K24 takes up more space vertically, but a small engine bay doesn't make a difference.
You'd need the whole front subframe from a 8G Si. And a wire harness. And an ECU...and a flash pro.
I guess it would be easier in that respect with a RSX. Or you could just buy a TSX....which is a better car overall than a RSX or an Si.
Old Feb 16, 2014 | 09:42 PM
the z3 head is better then the k24a2 one and yes I know the z3 was 05-06 but I was just planning on getting a skunk2 ultra series manifold for it to deal with the lack of throttle cable like the one I have on my current B-series. I hate working on cars with a craped engine bay that's all lol, yah had already budgeted for the flash pro. I can't afford a nice 06+ TSX-S plus they're heavy I'm just looking for a more modern track car.
Old Feb 17, 2014 | 02:56 AM
B serious's Avatar
The Z3 is from a 06+ civic Si. Its Drive By Wire.
The K20A3 is from an EP3 (02-05 civic Si) and it doesn't have real VTEC. It has a throttle cable. This would be a huge downgrade for the K24A2, which has real VTEC.
If you're looking for a " more modern track car", buy a 06+ Si. A 06+ EX will make a worse track car starting point than a TSX. TSX's have a better chassis lay out and are more "sporty" to start with than an EX. They're quick right off the bat amd have better brakes/handling. The RSX is OK as a track car if you know what you're doing. But the chassis isn't quite as good as a DC2. The base model has smaller brakes than a Type S...I don't know the various other differences except the drivetrain (Duh).
Why don't you try for a DC2-R or S2000 or 06+ Si....or even a RSX-S, I guess. Better starting points for a track car. Albeit slightly higher starting cost....but lower cost to prep or be competitive. Especially a S2000...which is basically the fastest car ever made
Old Feb 19, 2014 | 08:33 AM
vladd's Avatar
The K20A3 also came in the base RSX. The one in the base RSX came with a plastic IM, while the one in the 02-05 Si came with an aluminum one.
The 06-11 Si is a better car than the RSX. It has a better suspension design (more strut travel, steering rack is placed lower, etc), easier to flash ECU, more airbags, better seats, better stereo, etc. OP, if you're set on a k24, find an 06-11 Si and swap the k24 into it. If you find one with a good motor, you can sell it for probably more than you'd buy the k24 for.
Old Jan 15, 2019 | 07:04 AM
Noah Vargas's Avatar
thanks.
Old Jan 15, 2019 | 07:05 AM
I have a 2008 civic base model I wanna k swap the engine and turbo it its Project Coyote Killer once I'm done this car is gonna be fast I just need a engine that will fit. Can anyone help
way2much
20
Dec 28, 2007 05:37 AM
HondaGSX
11
Apr 3, 2007 10:47 AM
ImportReview
36
Aug 6, 2002 11:31 PM
6SPD_EK
15
Nov 2, 2001 10:47 AM
Civic Hatch Boy
Oct 18, 2001 12:29 PM
