Bad shake on take off
Old Feb 7, 2014 | 07:49 AM
Cashmoney061596's Avatar
Default Bad shake on take off
So when I take off from a dead stop in 1st gear, my car shakes like hell really hard. I checked my mounts and the two front motor mounts were cracked all the way through and I replaced those, and the rear mount was fine, but this shaking still persists. I'm getting around to changing it soon, but im aware that my clutch is very worn, so could this be my problem?
Old Feb 7, 2014 | 07:53 AM
Discosteak's Avatar
Default Re: Bad shake on take off
warped flywheel,
Old Feb 7, 2014 | 07:56 AM
crazyhouse2011's Avatar
Replace clutch and resurface or replace flywheel. Should fix that.
Old Feb 7, 2014 | 12:28 PM
austinkli's Avatar
Actually, it is probably the bearing in there. Either way, flywheel or bearing, replacing the clutch (get the entire kit) will fix this most likely.
shadowman
Jul 24, 2012 06:40 PM
ivan93egreppin210
Feb 10, 2010 04:22 PM
itslogz
Mar 19, 2008 02:24 PM
vtechatch
Sep 25, 2007 09:17 PM
k_lude
Oct 31, 2006 11:27 AM
