EJ8 with Y8 swapping to a B18C1 questions
I am looking into building up and Swapping out the D16Y8 in my 98 Honda Civic EX (EJ8) for a B18C1. Besides Harness and ECU that will need to be changed as well I can't seem to dig up what Manual trans the C1 uses and what axles I will need to use as well. Any advice or suggestions would be appreciated.
Cool Cool Island Breezes. BOY-EE
I would do a search to find a more in depth answer.
You need quite a few things. Shift linkage, mounting brackets, mounts, a t bracket from a 99-00 Si, a 2 post driver side upper mount bracket, ECU, a sub harness for intake butterfly operation, a CR-V AC mount if you want to re use your D series AC compressor.
Axles from any 92-01 B series car.
All 94-01 Integra transmissions say S80 on them. At the very least, you want a S80 from a GSR. The B16A2 (S4C), hydro B16A or ITR/CTR trans is a huge upgrade for the B18C1.
Again, do a search. There are a million people who have done this swap. Ask more specific questions when you have a grasp of it all.
tampabud
13
Feb 20, 2019 10:11 PM
Azxster
Sep 5, 2007 10:00 AM
