is it the regulator? 98 civ window jerks when 4 inches from being all the way up
Old Feb 4, 2014 | 01:53 PM
98civ98's Avatar
Default is it the regulator? 98 civ window jerks when 4 inches from being all the way up
have a 98 civic ex coupe (not sure if that is relevant) and the driver power window was off track and all messed up. so, this morning i took the door panal off and unscrewed the 10 mill bolt behind the speaker to put it back on track....all fine and dandy. when i was rolling the window up it got about 4 inches from being all the way up and it stopped and started clicking LOUD. not even sure if the word "click" would be correct. it jerks the window. almost as if a gear of somesort was slipping. idk. it's so bazaar. i unplugged the windows power and pulled the sucker (window lol) all the way up with my hands. do you think it's the window regulator? not sure if it would be the motor since the window goes up and down (for the most part) relatively well.
also, the power lock on the passenger side doesn't lock and unlock and stiff to move manually. any suggestions?
Thanks so much for y'alls help.
Old Feb 4, 2014 | 02:11 PM
Former User's Avatar
Default Re: is it the regulator? 98 civ window jerks when 4 inches from being all the way up
It's generally a bad regulator. The cause is usually a bad scissor joint.
Lock- try lubricating the latch.
Old Feb 4, 2014 | 02:31 PM
98civ98's Avatar
Okay, I had kinda assumed so, but was still trying to stay optimistic and was hoping for a "quick fix" answer lol.
for the lock, should i use a silicone based lube like recommended for the window seals? or will wd-40 do the trick?
Old Feb 4, 2014 | 02:32 PM
I'd use grease.
Old Feb 4, 2014 | 02:40 PM
98civ98's Avatar
alright, thanks so much for your help!!
Jessgut89
Oct 21, 2015 07:46 PM
rjb8806
Mar 17, 2013 08:06 AM
Spithead051
10
Jun 28, 2011 04:56 AM
bartino
Nov 7, 2009 12:23 PM
addiction2bass
Jun 7, 2006 02:46 PM
