96 Civic - How to check if ecu was upgraded?
Old Feb 3, 2014 | 05:08 PM
Ender_vci's Avatar
Default 96 Civic - How to check if ecu was upgraded?
I bought a 1996 Honda civic lx from my brother he had a new engine put into it a year or so before i bought it and when i was looking around the Engine i looked up the stamp on the block and it said d16y8 witch is a vtec correct?
How would i check to see if the ecu was upgraded? i guess im just trying to figure out a easy way to tell if its just the block or if the rest of the parts went with it..
Old Feb 3, 2014 | 05:24 PM
B_Swapped93's Avatar
Default Re: 1996 Honda Civic
Well the ECU will have to be an obd1 one to be chipped so first see if that's the case there will be a jumper since you have an obd2 car. here's how to tell just look at the plugs...Ya Y8 is a SOHC VTEC engine nothing special.
Old Feb 3, 2014 | 05:28 PM
Former User's Avatar
The Y8 uses a P2P ECU. Is that what is installed?
You will also want to check whether you have a Y8 head. The head code can be seen in the area around the exhaust manifold.
Old Feb 3, 2014 | 06:53 PM
Ender_vci's Avatar
Default Re: 96 Civic - How to check if ecu was upgraded?
This my first honda so I'm not sure what the p2p stands for.. edit: Ok looked at ecu tag it said the stander part number with a p2p-a71 on the ecu.. i look at the heads tomorrow what number am i looking for there?
Old Feb 3, 2014 | 08:08 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
In between the 2nd and 3rd cylinder exhaust port on the head will be a casting stamp code. Pxx-xxx followed by the year circle stamp.
Example in this post here.
And the head code list can be found here in the first post.
Old Feb 4, 2014 | 05:22 PM
Ender_vci's Avatar
Stamp on the head is p2j-5
Old Feb 4, 2014 | 05:43 PM
NotARaCist's Avatar
I never narc'd on nobody!
So you have a stock D16Y8, and a stock D16Y8 ECU. No, the ECU was not upgraded.
Is there any particular reason you're asking (any problems?), or were you just curious?
Old Feb 4, 2014 | 06:27 PM
street_racer_271's Avatar
Upgraded as in chipped? Take the cover off and look at the top right corner. Plugs on the ecu facing down
Old Feb 4, 2014 | 06:37 PM
NotARaCist's Avatar
Please read a thread before jumping in. OP has an OBD2 ECU - it isn't chipped.
Old Feb 4, 2014 | 07:24 PM
Ender_vci's Avatar
I was just trying to see if it was vtec.. and if it was setup to run the vtec its a LX and i ran into a few problems ordering parts.. i know my brother had a shop replace the engine about a year before i bought it i was jsut curios how far they went on the engine replacement.. a 1996 honda civic LX camewith a d16y7 correct? what i meant by the upgraded ecu was did they put in a ecu to run that motor..
Old Feb 4, 2014 | 07:26 PM
NotARaCist's Avatar
Yes, from what you've told us, they put the proper ECU in for that motor.
Zeroamaze
May 23, 2019 12:59 PM
Nickhozel
Feb 16, 2018 08:18 PM
sohc-civic
May 22, 2012 04:32 PM
Bakado
Feb 17, 2012 03:43 PM
n_senn
21
Aug 3, 2011 07:30 AM
