96 Civic - How to check if ecu was upgraded?
I bought a 1996 Honda civic lx from my brother he had a new engine put into it a year or so before i bought it and when i was looking around the Engine i looked up the stamp on the block and it said d16y8 witch is a vtec correct?
How would i check to see if the ecu was upgraded? i guess im just trying to figure out a easy way to tell if its just the block or if the rest of the parts went with it..
Re: 1996 Honda Civic
Well the ECU will have to be an obd1 one to be chipped so first see if that's the case there will be a jumper since you have an obd2 car. here's how to tell just look at the plugs...Ya Y8 is a SOHC VTEC engine nothing special.
The Y8 uses a P2P ECU. Is that what is installed?
You will also want to check whether you have a Y8 head. The head code can be seen in the area around the exhaust manifold.
Re: 96 Civic - How to check if ecu was upgraded?
This my first honda so I'm not sure what the p2p stands for.. edit: Ok looked at ecu tag it said the stander part number with a p2p-a71 on the ecu.. i look at the heads tomorrow what number am i looking for there?
In between the 2nd and 3rd cylinder exhaust port on the head will be a casting stamp code. Pxx-xxx followed by the year circle stamp.
Example in this post here.
And the head code list can be found here in the first post.
I was just trying to see if it was vtec.. and if it was setup to run the vtec its a LX and i ran into a few problems ordering parts.. i know my brother had a shop replace the engine about a year before i bought it i was jsut curios how far they went on the engine replacement.. a 1996 honda civic LX camewith a d16y7 correct? what i meant by the upgraded ecu was did they put in a ecu to run that motor..
Bakado
02-17-2012 03:43 PM
