Greddy Oil Feed Lines
Old Oct 28, 2002 | 07:32 PM
DeepSi's Avatar
Default Greddy Oil Feed Lines
Can somebody please post the part numbers to make the stainless steel braided lines for the oil feed line? Mine is leaking and i need to replace it, and i can not drive it, because the oil drops on the downpipe and a lot of white smoke comes from underneath the car. i really need my car fixed, and appreciate the help guys.
The t3/t4 oil feed lines are different than the greddy ones.
-deepsi
Old Oct 29, 2002 | 12:42 PM
DeepSi's Avatar
Default Re: Greddy Oil Feed Lines (DeepSi)
anybody, i have spent hours searching
Old Oct 29, 2002 | 01:25 PM
Carlito Brigante's Avatar
did you try calling ben@importparts? he might have the hookup, he does for all of us lol.
Old Oct 29, 2002 | 01:32 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Greddy Oil Feed Lines (fiaddictedsi)
Deep, did you install the coper washers? If you didnt, thats all you need then.
art
Old Oct 29, 2002 | 02:16 PM
madman604's Avatar
Greddy does not sell anything separately. Want a new greddy hose? buy a new greddy turbo kit.
or goto a hose sales/fabrication place and get them to make a new one. SS braiding is not necessary. Just show em the old hose and they can duplicate it.
Old Oct 29, 2002 | 02:26 PM
Tetsuwan Atomu's Avatar
Default Re: Greddy Oil Feed Lines (Turbo E)
OK, I just spent a half hour putting together a shopping list for you. Keep in mind this is exactly how I did my feed/return system. I decided not to use the factory oil sensor because i went with a mechanical oil pressure gauge that runs off the feed "T" coming off the block. Also I used a union in the pan---drilled bigass hole and sealed with silicon, in this case Im giving you stratoseal p/n so you can do it right (which I didnt do--in light of getting turbo install done)
All part numbers are from amstreetrod.com ---best prices and parts are always in stock.
Feed:
1/8 nipple for block -- 991101
1/8 "T" -- 991701
1/8 to -4AN -- 981604
(2 needed) -4AN straight swivelseal hose ends -- 300104
(4 ft needed) -4AN ss hose -- 400040
For adapter to turbo you will need one of these depending on the size of the hole on the turbo itself.....
1/8 npt hole 982204 (Smaller T3's use this one I believe)
1/4 npt hole 982244 (This was the one I used for my t3t4)
Return:
Aluminum return flange found at turbocharged.com p/n is 20259.
-10AN flange side male to hose -- 824510
(2 ft needed) -10AN hose -- 400100
-10AN 45 to pan fitting -- 804610
-10AN union for tapping pan -- 981510
-10AN bluhead nut for union in pan -- 992410
Stratoseal for union (package includes 2) -- 178014
here u go...someone from here did this....I saved it on my comp
Old Oct 29, 2002 | 03:23 PM
DeepSi's Avatar
Default Re: Greddy Oil Feed Lines (Arturbo)
art
The actual hose is coming out of the crimp hose ends and the oil is leaking from there.
I can build the lines and i know most of the parts i am just having a problem with the part that goes into the turbo. The Banjo Bolt that goes into the turbo is inverted flare, and i can not find a hose end that has a flare end that will pug into the inverted flare on the turbo.
Does anybody know the part that will go into the turbo and i can work from there.
thanks for your help guys. Second day without car and it sucks.
[Modified by DeepSi, 4:23 PM 10/29/2002]
Old Oct 29, 2002 | 03:24 PM
DeepSi's Avatar
Default Re: Greddy Oil Feed Lines (00'ex)
Feed:
1/8 "T" -- 991701
Return:
Thanks, i have seen this post and know the parts but this is for t3/t4 turbos. greddy is a little bit different. I just need the portion that plugs into the turbo.
anybody?
Old Oct 29, 2002 | 09:40 PM
just installed a steel braided oil return line on my greddy kit
i simply cut the turbo flange a bit then threaded the inside of it to 3/8, used a 3/8 to -10an 90 degree bend swivel seal hose end earl fitting, mated that up with a 1ft of steel braided hose, then connected the hose to a -10an to -10an 45 degree bend swivel seal hose end earl fitting which connects to a -10an flange which is welded to the oil pan
you will have to cut the steel braided hose to fit, because 1ft is more than enough
<http://www.anplumbing.com> is the place i got my hose end earl fittings at, and the part numbers i listed below
804610 Swivel-Seal 45 deg. Tube Hose End
829011 90Deg. Swivel-Seal Hose End Male Threaded
400100 Premium Racing Hose. THE BEST! (Use Swivel Seal or Auto-Fit Hose Ends)
967110 Steel Weld Fitting
hope that helps
for everything it costed about $80
_______
how bout this one?? this was done by roaring turtle...for greddy sohc kit...I am thinking all greddy turbo has the same size in return line...hope this helps...
Old Oct 29, 2002 | 11:29 PM
Sprockets's Avatar
Greddy turbos use different fittings than T3/T4 for the feed line. Don't use -4AN, use -3AN. Get the braided teflon hose. The hose you buy will have a much smaller outside diameter than the stock Greddy hose, but that's just insulation, don't worry. You'll need to get a 10mm x 1.25 banjo bolt (or reuse the one you have), a 10mm banjo with -3AN male fitting. Make sure you use 2 new copper washers. Don't reuse the old ones. From there just get whatever adaptor you'll need to attach the other end of the -3AN hose to NPT. If you have a problem finding any of this stuff, let me know and I'll look it up for you. I have some links saved.
Old Oct 30, 2002 | 09:39 AM
DeepSi's Avatar
Default Re: Greddy Oil Feed Lines (Evil Beaver)
Thanks Evil Beaver, this is exactly what i was looking for. i did not know the sizes of the banjo bolt and the bolt. Thanks a lot.
-deepsi
Old Oct 30, 2002 | 10:05 AM
quis23's Avatar
hey can you post up those links you have? i trying to find that banjo bolt and i'm having no luck. thank you.
Old Oct 30, 2002 | 01:42 PM
DeepSi's Avatar
Default Re: Greddy Oil Feed Lines (quis23)
i am in the middle of putting everything together but here are all the parts that you need to replace the greddy oil feed lines.
All parts are from AeroQuip (From Tee to turbo):
1. FCM2000 -- -3AN x 1/8 fitting adapter
2. FCM1100 -- -3AN Straight Hose End
3. FBC0300 -- -3AN Telfon Racing SS Braided Line (atleast 4 ft)
4. FCM1100 -- -3AN Straight Hose End (Same as #2)
5. FCM2947 -- -3AN x 10mm Banjo
6. FCM2923 -- 10mm x 1.25 Banjo Bolt
for future reference, mods please archieve this for searching purposes.
-deepsi
Old Oct 30, 2002 | 01:45 PM
DeepSi's Avatar
I will post later on how to upgrade the rubber oil to a SS Braided line. I did this already and it works very good.
-deepsi
Old Oct 30, 2002 | 02:03 PM
DeepSi's Avatar
All parts are from SummitRacing and are Earl's Performance Products (From Turbo to Oil Pan):
1. H TZ-7190 -- Turbo Oil Outlet Flange (http://www.hahnracecraft.com/hahn/parts/install.htm)
2. H TZ-9120 -- Gasket (http://www.hahnracecraft.com/hahn/parts/install.htm)
3. EAR-967110 -- -10 AN, male, steel, natural finish, weld fitting
4. EAR-804610 -- -10AN 45 degree hose end
4. EAR-403010 -- -10AN 3ft SS Braided Perform-O-Flex
5. EAR-309110 -- -10AN 90 degree hose end
6. EAR-967110 -- -10 AN, male, steel, natural finish, weld fitting
Weld #1 and #3 together
Weld #6 to oil pan
hope this helps people out in the future. Works great
-deepsi
[Modified by DeepSi, 3:07 PM 10/30/2002]
Old Oct 30, 2002 | 07:37 PM
quis23's Avatar
Old Oct 30, 2002 | 07:49 PM
falcongsr's Avatar
What is this crap?
deep you're in CA now? crap there is a truck shop here that will make an EXACT copy of that line for you with 300psi crimp connectors and banjo fittings and all...
crap! coulda went there would have been under $25.
Old Oct 30, 2002 | 08:04 PM
DeepSi's Avatar
Default Re: Greddy Oil Feed Lines (falconGSR)
Yeah i am back in CA till FEB when i finish school, and then i am moving back to Dallas to continue my job. Yeah i would have been nicer to spend $25, instead of $70. oh well.
Old Nov 12, 2002 | 03:20 PM
willyboyK20's Avatar
would those part numbers also work for the tdo4-15g sohc turbo
Old Nov 12, 2002 | 04:00 PM
DeepSi's Avatar
Default Re: Greddy Oil Feed Lines (willyboyD16)
Which parts are you refering to the feed/return?
Old Nov 12, 2002 | 04:55 PM
Boostless97Lude
Guest
Posts: n/a
i'm not sure if someone said, if they did, sorry for reapoeting, but the GReddy line uses an inverted flare, you will have to change that most likely.... i know i am
Old Nov 12, 2002 | 04:56 PM
DeepSi's Avatar
Default Re: Greddy Oil Feed Lines (Boosted97Lude)
Yep that is true , that is why you have to replace the banjo bolt on the turbo.
Old Jan 10, 2003 | 10:34 AM
I am refering to the return line. Because I looked at the hahnracecraft site about the part # HTZ -7190 and it said it would only work for tdo5/tdo6 turbos. I have the small tdo4. Will it work anyways?
PS: Sorry for the late reply.
Old Jan 10, 2003 | 10:53 AM
Smashback's Avatar
hahnracecraft.com sells an adapter fitting to connect a -4 hose to the oil feed inlet on Mitsubishi turbos...just a thought
Well, sonofabitch, I guess somebody else already mentioned it
[Modified by Hatchblack, 7:54 PM 1/10/2003]
Old Jan 10, 2003 | 04:10 PM
Default Re: Greddy Oil Feed Lines (Hatchblack)
will those adapters work with the smaller tdo4 turbos
