Continued transmission research...
I need a new tranny. Currently I have a stock tranny in my 00 DX (D16Y7). I've got grinding in 2nd gear - randomly - and I don't grind my action. I've read from another post that if I keep the engine from the car, I need to get a D series transmission. How the heck do I figure this out?!
Just have the transmission rebuilt if you want to keep it stock. If you want more performance you can have it rebuilt and change the FD or use a Z6 or Y8 transmission.
Not as easy as it seems. There's no one in this general area that could do it quickly within my timeframe. My work school schedule is erratic and difficult. Replacement is cheaper. Plus, an upgrade is always better than what one has.
I am looking for more performance - albeit one very slow, excruciating step at a time. My tranny's fairly important - I figure since that's a bit unhappy right now, I'd better handle that first so I can keep driving.
The final drive is the countershaft and ring gear on the differential. The lower the numerical value of the final drive the quicker the car will accelerate, the tradeoffs are mileage and top speed. Top speed should never be an issue since even with the shortest/lowest geared transmission available for your engine other factors will limit your top speed before the transmission ever does. The same goes for 1st through 5th gear, the lower the number the quicker the car will accelerate. A Z6 or Y8 trans is the lowest geared drop in replacement available.
Well, that makes sense.
Thanks for the info! I'm searching like mad now for either the Z6 or Y8 as both you and Aquafina had said. Now that I understand final drive, I know what to ask and look for. I'm not interested in getting hosed by some shifty (pun notwithstanding...) Dealer or seller because I don't know the right info.
Now I just have to find one.
wolfie98
Oct 21, 2007 07:45 PM
