Tachometer on Cluster above 1k
Old Jan 31, 2014 | 12:29 PM
andre3wap's Avatar
Default Tachometer on Cluster above 1k
Hello guys,
I have a 00 Civic Hatch. I replaced the original cluster with one that has a Tach inside of it, I've installed for a few weeks now. Ever since I installed it, I've noticed that the needle is always over the 1K gauge, even in park when the car is warmed up. I've never seen it sit on the 0 mark. What could be the issue? Photo below
Thanks alot
Old Jan 31, 2014 | 12:32 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Tachometer on Cluster above 1
If the car is running it should never hit zero. If I recall, 650-750 RPM is the normal idle once warm. Not sure why your's never goes below 1000.
Old Jan 31, 2014 | 01:03 PM
andre3wap's Avatar
Ah ok, thanks for that. Could it be related to my TPS ? another issue is, when I put the car in 'D' it drives kind of fast, without me even touching the Gas..
Old Jan 31, 2014 | 01:07 PM
94_civic_dx's Avatar
your throttle cable may be to tight ? try adjusting it maybe
Old Jan 31, 2014 | 01:10 PM
NotARaCist's Avatar
I never narc'd on nobody!
You need to adjust your idle speed.
Old Feb 1, 2014 | 08:05 AM
Former User's Avatar
This^
...and also clean the IACV and throttle body. If you get no joy, then adjust the idle speed exactly as described in the diagram posted above using an external tachometer or scan tool to get an accurate rpm read.
Wait -- even with the engine off?
jmarquar
Aug 26, 2013 11:17 AM
S13Morgan
Dec 4, 2011 07:16 AM
EG-HK
Sep 14, 2007 08:05 AM
anavrin351
Apr 6, 2007 04:56 PM
dcfour
May 8, 2005 02:32 PM
